Defender 90 ST Window Tops/ Bolts - Defender Source
Old October 23rd, 2015, 02:31 PM
jyoungjr01's Avatar
jyoungjr01
95 D90
Guys,
The truck I bought has not had the window tops off in years. The bolts are stripped and will not come off. I am assuming that I am going to have to take off the interior door panels to access the bolts. Can anyone give me some insight into what would be involved in getting the door tops off and taking off the door panel. I know that this is not supposed to be too dificult but I am just looking for advice before I start as to what is involved and how to do it. The help is great espcaially being a new guy just getting into this stuff.
Old October 23rd, 2015, 02:32 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Are your speed nuts just free spinning or something? The bolts are studs and don't need to come off. Once the speed nuts are off, just rock the window back and forth gently. You may lose some paint from your cappings to the gasket.
Old October 23rd, 2015, 02:34 PM
jyoungjr01's Avatar
jyoungjr01
95 D90
Yes, when I turn the wrench the bolt is turning but the nut is not moving I can hear the head of teh bolt twisting.
Old October 23rd, 2015, 02:35 PM
D90Overkill
David Frank
1995 ST #2615
Crap. The speed nut should be turning with the bolt if the bolt is free. Panels come off easy enough, but the closure on the nut is zero when affixed properly, so I don't think you'd have anything to grab onto.
Old October 23rd, 2015, 02:36 PM
rovertrader's Avatar
rovertrader
Dale
The bolt is threaded into the top, so continue unscrewing realizing you are removing the bolt, not the nut. Pretty common issue actually...
Old October 23rd, 2015, 02:38 PM
D90Overkill
David Frank
1995 ST #2615
Ahh. Makes sense. I learned something. There ya go.
Old October 23rd, 2015, 02:54 PM
jyoungjr01's Avatar
jyoungjr01
95 D90
Thanks Guys, Appreciate the input!
Old October 23rd, 2015, 03:22 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
They will probably be stuck in place, and as another poster commented, and take some paint off when you do break them free, but make sure someone has a hand on them when you take the last bolt out, last thing you want it to do is flop off the door and smash on the garage floor.
~Scott T.
'95 D-90 ST - AA Yellow
Old October 23rd, 2015, 03:29 PM
Defender 90 Window Studs - Soft Top
90, bolts, defender, defender 90, top, window
Pre Summer Exmoor Trim USA Top Sale (Mesh UV Tops, Surrey Tops, Bimini Tops) ExmoorTrimUSA The Vendors Loft 6 June 9th, 2017 04:26 PM
Badger Soft top - Proper Storage - Full Soft Tops and other tops rijosho Defender Technical Discussions 10 August 4th, 2010 12:31 PM
Removable Window Bolts - Free 97-D90-736 For Sale - Parts 2 August 30th, 2009 04:48 PM
ST doors, Door Tops and Stainless Bolts tomaco1 For Sale - Parts 7 June 16th, 2009 09:25 PM
Stainless window bolts Peter Defender Technical Discussions 1 July 6th, 2004 10:44 AM
