Defender 90 Question. - Defender Source
Old April 7th, 2013, 12:50 PM
mwhorne
Matthew Horne
1997/defender 90
Hi All,
I have a tech question. I have a 97 D90 soft top, that I have had for about a year. Just recently it has started giving me problems: It starts up no problem and will run well for a while, but if I stop and then get back in the car to start it up, it will turn over but will not idle. You can't get it in gear with out it dying. It seems like it is too hot or over heated. The gage says it is fine, right in the middle. If I let it sit for a 2-4 hours, it will start right up and then we repeat the process. I did have the fuel lines replaced last summer, because it was doing the same thing but would not turn over. It now turns over but won't idle.
Any ideas?
Also,
Anyone know how to remove the windows/frame etc off of the doors?
Thanks much. Matt
Old April 7th, 2013, 12:58 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
First...Welcome. Second there are several threads covering these topics. Research the threads. simple problems really...you'll find other useful information in your search.
Old April 7th, 2013, 12:59 PM
Assume all normal maintenance has been done.
I'd initially make sure that the IAC and MAF are clean.
Old April 7th, 2013, 01:04 PM
mwhorne
Matthew Horne
1997/defender 90
Rocky thanks!
IAC? and MAF? Sorry, not a car guy could you tell me what those stand for. Thanks learning
Old April 7th, 2013, 01:26 PM
If you see the search button you can usually put some keywords as your symptoms and you'll find threads on your topic fully covered (usually). Other than that, google things you don't know, and we can help fill in the blanks from there. For example, if you google "land rover maf" the first result tells you maf = mass air flow.
Welcome to the forum.
Old April 8th, 2013, 05:07 PM
jijalicious
Jiman Khosravan
'94 D90
Ignition coil could be going bad... had similar issue.
Old April 8th, 2013, 05:22 PM
Do you have a check engine light illuminated? If so, get the code read and report back.
To remove the frames off the door, I made a post about that a while back. Basically remove the nuts at the bottom and then you have to pry them off very carefully.
Old April 12th, 2013, 11:25 PM
mwhorne
Matthew Horne
1997/defender 90
Ok so i took the car in and they ended up replacing the o2 sensors in the rear, which removed the check engine light. They cleaned the IAC and it now idles. Awesome!!! I left the shop and driving home and notice the right and left turn signals don't work. You can turn them on but no blinking. They worked before I brought it in. Any ideas?
Old April 13th, 2013, 12:27 AM
Hazard switch. Give it a light pull.
Old April 13th, 2013, 01:10 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Let it sit for 2-4 hours while you drink. All will be fine after drinking for 2-4 hours.
Old April 13th, 2013, 09:50 AM
mwhorne
Matthew Horne
1997/defender 90
Jason,
It worked. Slight tug on the hazard's. Thanks.
Old April 14th, 2013, 09:52 PM
mwhorne
Matthew Horne
1997/defender 90
Ok
The radio turns on but no music. I called and got the security code. Do I have to let
The car run for 1.5 hours before entering code. Right now code does nothing.
Thanks.
Old April 14th, 2013, 10:04 PM
NikosF
Nick
1995 NAS D-90
Ok
Thanks.
You should be able to enter the code immediately on turning the ignition on and the radio should work immediately thereafter. I just had to do it yesterday because I had disconnected my battery to hook up a trickle charger in Feb because I wasn't driving much.
The idea of someone stealing my radio as anything other than a prank is hilarious.
1995 NAS D-90 Alpine White
Old April 14th, 2013, 10:08 PM
jafir's Avatar
jafir
Jafir Elkurd
Defenders have radios?
90, defender, defender 90
'97 NAS Defender 90 ST roll cage and other ST specific components for sale LenB For Sale - Parts 11 August 21st, 2011 09:24 PM
Defender 90 Scoop For Sale - Vehicles 0 December 10th, 2005 11:46 PM
UK defender 90 110 130 brochure mpodgorski For Sale - Parts 1 June 25th, 2004 02:13 PM
Defender 110 and 90 tool kit mpodgorski For Sale - Parts 5 May 4th, 2004 09:17 PM
Defender 90 Hardtop sharknet For Sale - Parts 1 March 14th, 2004 10:50 AM
