Defender 90 Jockey seat stops - Defender Source
Old April 2nd, 2016, 07:52 PM
Yorkie
Mark Whitehouse
1989 D90
Hi
I have a Defender 90 which has the 4 sideways facing jockey seats. The U shaped piece of tubular metal which rests on the floor of the Defender when someone sits in the seat sometime slips out of the fixing on the seat base. It seems as though there may be some rubber stops or something missing that stops this from being an issue. Does anyone know if there is a part available to stop this occurring?
Cheers Mark
Old April 2nd, 2016, 08:04 PM
phoenix37's Avatar
phoenix37
john
post a pic of how you place the support...It should go under the seat and rest against the tub not face inward towards the seats on the other side.
Old April 2nd, 2016, 08:17 PM
87 D110 (Ruby)
yes...it doubles back at a 45deg angle under the seat against the tub sides. It shouldn't need anything more to sit in the bracket on the underside of the seat base.
Old April 2nd, 2016, 08:28 PM
Yorkie
Mark Whitehouse
1989 D90
Sorry guys not explained myself very well. The U shaped tubing that effectively acts as the seat 'legs' when its in use is becoming detached from the seat as its slipping out of the seat attachment.
Old April 2nd, 2016, 08:31 PM
ssi19's Avatar
ssi19
scott
1995/D90
Squeeze the "u" arms together and remove it from the seat bottom. Then try to pull the ends of the u apart to widen the gap. Then put it back into the seat bottom. Should stay now.
Old April 2nd, 2016, 08:38 PM
Yorkie
Mark Whitehouse
1989 D90
Originally Posted by ssi19 View Post
Squeeze the "u" arms together and remove it from the seat bottom. Then try to pull the ends of the u apart to create more "outward" tension. Then put it back into the seat bottom. Should stay now.
Doh!! Many thanks!!
Old April 2nd, 2016, 08:39 PM
ssi19's Avatar
ssi19
scott
1995/D90
Let the record show I finally contributed something to this forum. Took 4 years.
90, defender, defender 90, top
F/S Powder Coated Seat Bracket Stops Buddie For Sale - Parts 7 February 29th, 2012 10:01 PM
rear bumps stops and rear spring seat jjstahl3 Wanted 0 January 18th, 2012 12:51 PM
Need Spare Carrier Bump Stops/Brackets Shake Wanted 3 February 17th, 2007 08:35 PM
High Quality extended bump stops Roadsiderob Defender Technical Discussions 3 August 28th, 2006 03:19 PM
Bump stops UpnOver Defender Technical Discussions 4 May 7th, 2005 11:55 AM
