Defender 90 frame differences over the years/engines - Defender Source
Old April 17th, 2014, 11:35 PM
madcowdungbeetle
Carter
Are there any differences in the location of the LT230 frame mounting holes on Defender 90/110 frames on trucks with the 2.5's, 200TDI, 300TDI, TD5, V8 and Puma/Tdci trucks using the front bulkhead outrigger as the datum for reference?
Old April 20th, 2014, 12:44 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Not really. Up to The Td5, they all had a bolt in gearbox mount.
300Tdi's used mounts on the removable crossmember.
Td5's were welded onto the frame, but you can just use a 300Tdi crossmember instead (i did this on the project90)
Not too sure about a pume 2.2/2.4, i've not crawled under one to find out.
Bulkhead positions are certinaly all the same up to the puma. And seeing as the puma fenders are more or less the same as every other defender before it, I'd hazard a guess that the outiggers are also in the same place too on those.
90, defender, defender 90, engine
Frame differences? - CSW vs Tithonus 110 Streaky Defender Technical Discussions 5 January 22nd, 2014 08:59 PM
Defender engines/ and my Defender going up for sale Korongo Misc. Chit-Chat 3 November 15th, 2013 11:33 AM
defender model differences wilyliang Defender Technical Discussions 6 September 26th, 2011 01:06 PM
jump seat backrest frame differences cgalpin Defender Technical Discussions 7 May 26th, 2011 08:44 AM
differences in Defender / disc front end ? Chris Velardi Defender Technical Discussions 4 October 7th, 2010 12:06 AM
