Defender 90 alternator - Defender Source
Old February 5th, 2015, 01:58 PM
TedJan
Ted Jancewicz
none
Hello Group,
1989 Defender 90 turbo diesel N/A,engine 19J.alternator not charging.Received a replacement alternator fron vendor,Part#RTC5680E which is a 65 amp unit whereas the old one is a 45 amp.Old alternator wiring has the classic Lucas style 3 wire(2 large brown and a smaller guage brown/yellow female spade connectors.).I know that the brown wires are constant 12v and the brown/yellow is the key on exciter wire.Replacement alternator has 2 electrical mounting studs,one large and one small.I believe that if I connect the 2 large brown wires to the large stud and the smaller brown/yellow wire to the smaller stud,it should work.Physical mountings appear to be the same,just have to check the pulley fit.
What say Ye?
Ted
ID:	112878   Click image for larger version
Old February 5th, 2015, 02:12 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
edit edit edit
Old February 5th, 2015, 02:22 PM
Yes, that is correct. It should work fine.
Old February 6th, 2015, 12:49 PM
TedJan
Ted Jancewicz
none
Thank you and it did work perfectly.Also,I did a voltage drop test on the brown/yellow wire and had an intermittent 3.5 volts with key on.Found loose plug at instrument cluster.
90, alternator, defender, defender 90
1984 Land Rover Defender 90 Alternator Zoinks Wanted 1 November 3rd, 2014 03:38 PM
Wtb: alternator pulley defender diesel Jaded-7 Wanted 2 September 11th, 2014 07:29 AM
Alternator Defender 300tdi lsudefender90 Defender Technical Discussions 0 January 16th, 2011 09:01 AM
120 amp Rebuilt Alternator 97 Defender RoverDude For Sale - Parts 0 December 17th, 2009 01:57 PM
Mean Green Alternator install tmore Defender Technical Discussions 4 May 11th, 2004 02:45 PM
