Defender 90 1997 NAS SW VIN Label Sample - Page 2 - Defender Source
Old July 3rd, 2016, 04:51 PM
Originally Posted by koshow View Post
. I doubt the previous owner will say anything. I'm running out of options in my opinion. Upset.
Post pics and details. Or a link to the for sale as if you still have it?
Old July 3rd, 2016, 07:13 PM
koshow's Avatar
koshow
Kenji
95/D90
Found the sticker at the footwell. The last owner was a genius and decided to cover it. You can see the top numbers but now I'm not sure if i should try and remove it because it will damage the sticker.
https://drive.google.com/file/d/0Bw-...ew?usp=sharing
I still cannot identify the vin on the frame as I think the ARB front bar is blocking it. My vehicle also has the Rockware skid plates installed. Didn't lift the car yet but will do it on Tuesday and remove what I need to.
What do you guys suggest about the footwell sticker? I don't want CHP to think it was intentionally altered.
Old July 3rd, 2016, 07:22 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
I bet your vin number on the frame is there and you just need to uncover it. The sticker shouldn't be an issue with Chp because they can accurately verify it with your frame vin and vin tag on the body. I'd try to remove that speaker component. Is it held on with screws? Check the outside of the footwell.
Old July 3rd, 2016, 07:25 PM
koshow's Avatar
koshow
Kenji
95/D90
It's stuck on there tight with a glue I cannot identify. May have to slowly chip away at it.
Does anyone know if the ARB front bar attachment is blocking the VIN on the footwell? I will look into this on Tuesday but just curious if anyone knows.
Old July 3rd, 2016, 07:28 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Here is where the vin stamp is on your frame. Can you see this part of the frame? If not, uncover it.
Old July 3rd, 2016, 07:31 PM
koshow's Avatar
koshow
Kenji
95/D90
Hmmmm. I think the Rockware skid plate is covering that. Do you mind telling me where this is exactly? Thanks for the photo!!!!!
Old July 3rd, 2016, 07:42 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
If you go take a look at your frame you will identify what you see in that photo. As others have mentioned, it's the right front outside of your frame.
Old July 3rd, 2016, 07:51 PM
phoenix37's Avatar
phoenix37
john
per this pic..
Old July 3rd, 2016, 07:59 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Probably some of that doublesided mounting tape.Try a hair dryer to heat it up a little and see if it will peel off.
Rent my
Old July 3rd, 2016, 08:46 PM
koshow's Avatar
koshow
Kenji
95/D90
Appreciate all the help.
Just to confirm, is there only one place on the frame where the vin is located? Anywhere else?
Old July 3rd, 2016, 09:06 PM
phoenix37's Avatar
phoenix37
john
[QUOTE=koshow;751679]Appreciate all the help.
Just to confirm, is there only one place on the frame where the vin is located? Anywhere else?[/QUOTE
YES!....NO!
Old July 5th, 2016, 07:39 PM
koshow's Avatar
koshow
Kenji
95/D90
Team,
Lucky day. The speaker component unit was actually screwed on, not glue, so after removing it you can clearly see the sticker!!
Went to DMV and waited over an hour to finally get all the registration out of the way. The Defender is officially a CA vehicle.
Thank you everyone for the help and I will also PM bridog63 an image of the sticker for his reference.
Old July 5th, 2016, 09:10 PM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
now that your truck is street legal bring it out to our next coffee/brunch on 23rd in Palo Alto.
Look for my thread on the Trips & Events discussion.
Old July 6th, 2016, 09:03 PM
koshow's Avatar
koshow
Kenji
95/D90
Will be in Amsterdam but when I return will do!
Will check your thread on frequency.
Thanks!!!
Old July 8th, 2016, 05:38 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Congrats!
Glad it worked out! I look forward to seeing you and your truck at a gtg. Enjoy! ;-)
Old July 10th, 2016, 03:47 PM
Chip's Avatar
Chip
Andrew
1994 NAS Defender 90
My 94 Defender's VIN sticker looks just like the 96 Disco one. Does the 97 Defender's sticker look the same?
Old August 9th, 2016, 12:57 AM
lamakdaddy
Kamal Raza
97 90
Originally Posted by bridog63 View Post
Need help here... looks like my VIN Label at the footwell is missing; no clue why it is gone, I am the 2nd Owner, have had this vehicle since 2006. All vehicle VIN numbers match up, so just replacing the missing label. Looking for a good photo of Defender 90 1997 NAS SW label. Found someone who can recreate this (vehicle vin stickers), yet need a good sample. If this works out, will share will ALL.
LRNA is no help, dealer is clueless.
If anyone can send a photo, would appreciate it!
Thanks.
Did you find a label supplier? please pm me with the details. thanks
1997, 90, 97, defender, defender 90, nas, vin
VIN label replacement outpost Misc. Chit-Chat 9 April 17th, 2016 08:35 PM
Alu-Box Sport Sample Tiktaalik For Sale - Parts 2 July 18th, 2015 06:51 PM
Tiktaalik Sample Sale Tiktaalik For Sale - Parts 14 March 21st, 2015 03:23 PM
Sample Warning Decals jjstahl3 The Flea Market 17 January 10th, 2014 07:31 PM
