Defender 300TDI smoking - Defender Source
Old May 23rd, 2013, 10:09 PM
graham's Avatar
graham
Graham Prentice
1996/Defender 110
I have a 1996 Defender with the 300TDI.
i was off road and submerged the truck. The engine stoped once it dipped to low in the water. Once the truck was removed from the water, the air cleaner and filter was removed and water drained from the air intake pipes. the engine was turned over in short rotations to push the water out. the engine started and ran fine with lots of power, although lost of initial white smoke.
the oil was changed, air filter renewed, gas tank drained and refilled. Now on cold starts it smokes and when driven for the first 1/2k the smell is very Diesel and white smoke.
after the 1/2 k drive, and i am out of my nieghbourhood, it runs fine.
Any suggestions.
gprentice@trebnet.com
Graham Prentice
"an agent that works"
Old May 24th, 2013, 09:35 AM
Santiago Montenegr's Avatar
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
Clean the water separator behind the rear left wheel.
Old May 24th, 2013, 09:45 AM
Or you bend a con rod....
Old May 24th, 2013, 09:48 AM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
Sounds like your timing is retarded. Perhaps the timing belt was stretched in this incident? You might check that out if cleaning the sedimentor doesn't do it.
Old May 24th, 2013, 09:57 AM
Did you remove the injectors before turning the engine over? If not there is real risk of damage.
Old May 24th, 2013, 10:02 AM
That would not matter. Any possible damage is done when it stalls...
I'm serious about the con rod. When these engines hydrolock, they bend con rods. Usually it is one cylinder, whichever one was in the compression stroke. They will still run perfectly fine. Compression is reduced and so cold starting is affected. The cylinder in question does not combust until the temps get high enough. This causes the smoke until you get into a bit of throttle. Once warmed up, you won't notice any problems.
Have a compression test done. If that shows something pull the head and check piston stickout. Pulling the head is quick and easy.
300tdi, defender
1994 Defender 90 300Tdi for sale Crash For Sale - Vehicles 3 March 5th, 2010 10:13 AM
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
Land Rover will not replace Defender dbwitt Misc. Chit-Chat 27 March 22nd, 2005 03:03 PM
Defender Gods Hate Me BradforD90 Misc. Chit-Chat 5 March 14th, 2005 11:59 PM
Thinking of selling my Defender...Help! boshea Misc. Chit-Chat 15 February 17th, 2004 01:54 PM
