defender 300tdi air cleaner mounting - Defender Source
Old March 5th, 2009, 03:00 PM
Hi
I have a disco 300tdi that I would like to put into a defender. i have the defender air cleaner and all the factory parts to mount it. The baseplate that holds the filter is held down by two of the head bolts. What is the consensus if I replace those two bolts? IIRC this is a torque-to-yield application so the bolts would have to be new. On other engines I have removed one head bolt and replaced it without issue but those were cast iron engines and re-usable bolts. I think with this arrangement I would have to take them both out at the same time in order to install the plate. Thoughts, ideas, personal insults?
D
Old March 8th, 2009, 12:05 PM
bump. anybody?
Old March 8th, 2009, 12:26 PM
Bastard.
Sorry, that's all I can offer.
Old March 8th, 2009, 02:07 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I did it on one of my 300tdi engines - but I didn't know any better at the time
Old March 8th, 2009, 02:49 PM
guess I asked for that! does put things in perspective though.
hooseier/chris: so you did the same thing and did not have issues?
thanks
d
Originally Posted by JimC
Bastard.
Old March 8th, 2009, 06:12 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
It is doing well, but I don't think I'll do it again - makes me nervous. Pulling engines is such a pain in the butt and it's probably not worth the risk.
Old November 18th, 2012, 12:27 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
Reviving the dead here!
So I am actually in the same boat now. The engine I got didn't have the bracket on. So I now have the bracket and see that it mounts under the head bolts.
What's the proper way to install the bracket? Do you need to get a whole new bolt set and retorque them all? New gasket? Or is it fine to remove the 2 and just retorque?
The engine is rebuilt so its already new stuff.
Pete
Old November 18th, 2012, 01:52 PM
bronco
I did this and the engine is still going strong after 3 years and a month and 19500 miles.
Go for it. I re-used the bolts. If they are not visibly stretched they should be fine.
Good luck,
Old November 18th, 2012, 09:22 PM
Broncoduecer
peter
D90
Awesome thanks. Are they pretty easily identified if they are stretched?
Pete
Old November 18th, 2012, 10:39 PM
So I have heard. Not seen it though. Suppose you could measure them, but I wouldn't worry about it too much. I was advised they could be re-used a few times without issues. There are other reasons/rationales I could give but basically I would just go for it. What are your options anyway?
Pete
Old November 18th, 2012, 11:16 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Peter, where did you get the mounting bracket? I need one but haven't been able to locate it. Do you have a part number?
Old November 18th, 2012, 11:58 PM
Britpart knocks em off. I bought mine from Duncan @ Britcar
Old November 19th, 2012, 12:26 AM
Turbofan's Avatar
Turbofan
Ethan
'73 SIII/ D90 Hybrid
I just went through this with a truck. My concern was the same. Les at RN told me it should be fine, so I just pulled those two put the bracket on and replaced the bolts (with new ones). Haven't had a problem yet.
Old November 19th, 2012, 07:49 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
The air cleaner mounting plate being caught by head bolts is a shitty set up imo, I was myself trying to find an alternative to that, but not that simple.
The head bolts can be re-use up to five times according to LR tech data. Seems a lot to me.
- Charles Eames
Old November 19th, 2012, 08:14 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
The head bolts can be used up to three times according to LR. I had the same issue on one of the trucks. I ended up making a bracket that bolted to the block and then supported the air cleaner clamps. I figured this was better than risking pulling the bolts. I have heard of a couple guys pulling the bolts with out any long term issues.
Land Rover 110
Old November 20th, 2012, 11:03 AM
Broncoduecer
peter
D90
RiftRover,
I got it with my engine stuff from David (atlcruiser) but it is a britpart ERR2850. I'm not sure where he sourced them from. Britcar or paddockspares can send them to you. Not sure if RN or RDS has any.
Ren Ching,
You're right not a lot of options other than redoing it all, which seems excessive.
I will guestimate that this would be the third time reused if I take them out. Once new, twice rebuild, and third myself.
These ones are the M10 head bolts?
300tdi, mount, tdi
200tdi air filter mounting bracket (defender) dave_lucas Wanted 2 December 4th, 2009 08:26 PM
300Tdi wings/ radiator finisher (defender) Lyman Wanted 2 March 8th, 2006 05:51 AM
Looking for Defender 300TDi intake JimC Wanted 2 June 20th, 2004 07:55 AM
