Defender 200tdi Turbo Garrett model number? - Defender Source
Old March 16th, 2016, 07:43 PM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Hi,
Does anyone know the turbo name/part number or model number for the Defender 200TDI?
Does anyone know a vendor who sells kits for the rebuild?
Michael
Old March 17th, 2016, 06:42 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I had good experience talking to Tim at Dingocroft.com. Higher$ items I still like to speak to the guy in the other side of the line to make sure we're in the same pages.
Old March 17th, 2016, 07:58 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Yours should have a metal id tag on it.
https://www.btnturbo.com/parts/model...discovery.aspx
~ Semper Fidelis ~
Old March 18th, 2016, 02:41 AM
DailyDrivenDefende
Michael
I think I am going to scrap rebuilding idea. Bolts and nuts are just stuck solid. Been Kroiling for weeks. Tried heating up with butane torch but no luck.
I suppose I will have to replace the entire manifolds along with the turbo when turbo goes bad? There is noticeable play on the shaft that I can feel but how much free play is normal on the turbine?
Old March 18th, 2016, 04:21 AM
Originally Posted by DailyDrivenDefende View Post
I think I am going to scrap rebuilding idea. Bolts and nuts are just stuck solid. Been Kroiling for weeks. Tried heating up with butane torch but no luck. I suppose I will have to replace the entire manifolds along with the turbo when turbo goes bad? There is noticeable play on the shaft that I can feel but how much free play is normal on the turbine?
You should be able to reuse your old exhaust manifold.
Old March 18th, 2016, 06:51 AM
1of40's Avatar
1of40
1of40
Mine was in the same condition. I even let a local machine shop give it a try. I had my flywheel in for resurfacing and happened to mentioned how tough of a time I was having pulling it a part. They said they'd like to give it a try but it was a no go without risking damage. I sold if for parts.
Old March 18th, 2016, 07:39 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
I have one ready for rebuild No frozen bolts.
------ Follow up post added March 18th, 2016 07:39 AM ------
Complete with manifold portion
~ Semper Fidelis ~
Old March 18th, 2016, 09:03 AM
Kroil won't help you there I'm afraid. You need copious amounts of heat that a butane (assuming you mean propane) torch just won't deliver. A MAPP torch might do the job, otherwise try oxy acetylene to get them cherry hot. Then they should break free. If you don't have an OA rig, try taking them to a friendly shop who will heat the bolts for you one at a time.while you remove them. Or, pay them to take them out.
A small amount of side to side play is normal. Look for axial play (in and out) in the shaft and look a the compressor blades for damage to the leading edge or evidence that it has been contacting the compressor housing. Also, check for oil contamination in the turbo outlet pipework.
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old March 20th, 2016, 01:38 PM
DailyDrivenDefende
Michael
Thanks for the information!
The threads on nuts and bolts on the turbo aren't that rusted visually but it is just the placement of these things doesn't allow proper delivery of the torque. I was able to loosen the turbo from the exhaust manifold and I am down to one nut on the downpipe that I have no straight access to it. I bet you know which nut I am talking about. Any tip?
I will check for the axial play later today.
------ Follow up post added March 20th, 2016 10:46 AM ------
Just as a resource for future reference:
turbo-product
Old March 20th, 2016, 02:04 PM
On the play issue there are very specific specs. Because they use plain bearings they must have play. You need to measure as there is no way to tell be feel unless you did this all the time.
Old March 20th, 2016, 03:31 PM
DailyDrivenDefende
Michael
Understandably, that is why I am inclined toward rebuiding it so I am not guessing or trying to feel if it is right. But i need to take this apart first to rebuild it so... down to one nut to get all the manifolds off of the turbo now.
Having said that, out of impulse, just bought a VNT from Allisport.
Old March 20th, 2016, 04:42 PM
speedpin's Avatar
speedpin
1985 130 Gen IV
Problem solved
~ Semper Fidelis ~
Old March 22nd, 2016, 01:56 AM
DailyDrivenDefende
Michael
Now should I get the head redone?
This hobby of ours sure does bring the disease out of us.
Old March 22nd, 2016, 07:23 AM
speedpin's Avatar
speedpin
1985 130 Gen IV
Take it off, inspect, clean, new head gasket. If its not broke don't fix it.
~ Semper Fidelis ~
200tdi, defender, mod, tdi
Garrett T25 Turbo for 200tdi Jonesy Wanted 26 November 7th, 2014 12:22 PM
Proper Defender high-turbo 200tdi Defender diesel enigne for sale (Gearbox too) ZombieMotors For Sale - Parts 1 August 19th, 2013 12:02 PM
Turbo Diesel or Diesel Turbo? Paul K Misc. Chit-Chat 11 April 11th, 2013 11:59 PM
Garrett T25 oil drain threads? o2batsea Defender Technical Discussions 9 September 5th, 2012 11:21 AM
Air Research M-11 (Garrett) tomaco1 Defender Technical Discussions 10 April 15th, 2009 03:51 PM
