Defender 200tdi airfilter bracket - Defender Source
Old March 8th, 2014, 07:51 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
Can someone post a pic of the air filter canister mounting bracket? I would like to get it as close to the proper location as I can. Thanks
Old March 8th, 2014, 08:21 PM
kinda just below the black plastic shock hole cap on the left inner fender well, it angles down in the front so the dump valve would be the low point
Old March 8th, 2014, 08:43 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Use these as a starting point, (Boner) started life as a turbo diesel so the filter could have been moved around a bit. There are no extra bolt holes on the inner wing so filter could have been there for the start. the only reason i question it placement is the filter does touch the body work at the front and some of the panel was beat in for the nose to fit.
Good luck
Name:	19-jan-12 061 (800x600).jpg
ID:	90965   Click image for larger version
Name:	19-jan-12 062 (800x600).jpg
Name:	19-jan-12 063 (800x600).jpg
ID:	90967   Click image for larger version
Name:	19-jan-12 064 (800x600).jpg
Name:	19-jan-12 065 (800x600).jpg
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old March 8th, 2014, 09:33 PM
solarguy's Avatar
solarguy
Abraham Bell
Thanks guys. Just needed a visual.
Defender 200tdi manifolds Aksantana Wanted 0 May 12th, 2013 07:57 PM
Defender Fusebox Bracket Miller Wanted 2 July 25th, 2012 07:12 PM
Defender transmission for 200tdi mattm Wanted 7 October 9th, 2009 10:30 AM
1991 RHD - Defender 90 Station Wagon - 200tdi AUTO - CDN$18,000 globallandrovers The Vendors Loft 0 March 4th, 2009 08:39 PM
Defender Cubby, Factory Stereo, Disk Changer, Bracket, and Harness boshea For Sale - Parts 12 February 13th, 2005 07:41 PM
