Defender 200tdi - Defender Source
Old May 2nd, 2016, 05:08 AM
maria
karen gallo
1992/tdi
Defender 200tdi
The rear axle doesn't operate and when I put the handbrake on it locks the rear axle and the front axle starts to move so the vehicle operates only on the front axle. All the gears are ok. Any suggestions as to what is wrong?
Old May 2nd, 2016, 06:28 AM
Something is broken in the rear axle.
Old May 3rd, 2016, 06:41 AM
maria
karen gallo
1992/tdi
derender 200 tdi
thanks was the wrong description , the rear prop shaft does not engaged any suggestions ?
Old May 3rd, 2016, 07:40 AM
What is read above is the rear prop shaft spins. When you apply the hand brake it drive forward.
Old May 3rd, 2016, 11:20 AM
maria
karen gallo
1992/tdi
right .hand brake on drives only with the front prop shaft
Old May 3rd, 2016, 11:32 AM
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old May 3rd, 2016, 11:41 AM
Likely the cast iron drive flange. Jack ea wheel up individually with the truck off but in gear. You will likely be able to spin one or the other.
Old May 3rd, 2016, 12:09 PM
Pull the halfshafts first. 5 bolts each side. A few minutes of time. As Doug says, look at the drive flanges as the splines can wear out.
Old May 3rd, 2016, 12:33 PM
maria
karen gallo
1992/tdi
4 wheels of the ground with engaged second gear the rear prop shaft is turning ,holding the rear turning prop shaft with my hands ,the front prop starts to turn so no drive going to the rear axle
Old May 3rd, 2016, 12:37 PM
Once again.... There is something broken in the rear axle. You need to start by removing the drive flanges on both sides to see what is broken.
Old May 3rd, 2016, 01:12 PM
Present:
1987 RRC- "Chewy 2"
Past:
Old May 3rd, 2016, 01:31 PM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Drive IS going to the rear axle: you've proven that the transmission drives the transfer case, and the transfer case is capable of turning both prop shafts.
The issue is where does the drive go after it enters the rear differential- a broken 1/2 shaft or rounded splines on the drive caps will present symptoms exactly as you've described.
You've received sound advice from some knowledgeable people, time to act on it!
Email is
Same place, new dogs.
Old May 3rd, 2016, 01:34 PM
fwiw, you should be able to drive your truck in diff lock.
This will confirm for you that the transfer case and transmission are fine.
Old May 3rd, 2016, 01:35 PM
maria
karen gallo
1992/tdi
splines are fine
Old May 3rd, 2016, 01:44 PM
splines are fine
If you are 100% certain of that, then you need to keep going.
Three possible failures....
1) Drive flange splines (not the half shaft splines).
2) Half shaft broken.
3) Differential broken.
maria
karen gallo
1992/tdi
diff lock mode exactly the same behavior
Old May 3rd, 2016, 01:46 PM
Roverlab
Trevor Griffiths
If applying the driveshaft brake gave the car drive and applying the CDL didn't, then I don't think the CDL is engaging.
Email is
Old May 3rd, 2016, 02:14 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
So in post #9 are you saying you can grab the rear prop shaft with your hands and stop it?
Old May 4th, 2016, 12:06 AM
maria
karen gallo
1992/tdi
yes not enough power on rear prop
Old May 4th, 2016, 12:30 AM
maria
karen gallo
1992/tdi
if the car is in first gear with out the handbrake applied taking your foot of the clutch to engage the gear but nothing happens the car does not drive,applying
the handbrake on then the front prop shaft turns and the car operates like fwd vehicle
using differential lock exactly the same behavior
200tdi, defender, tdi
200Tdi/300Tdi Exhaust Mount Locations D90/Disco 200Tdi Conversion edh Defender Technical Discussions 5 February 15th, 2016 05:08 PM
Proper Defender high-turbo 200tdi Defender diesel enigne for sale (Gearbox too) ZombieMotors For Sale - Parts 1 August 19th, 2013 12:02 PM
1983 110 200tdi defender (on new chassis) rovernutzz For Sale - Vehicles 0 December 27th, 2008 12:33 PM
What's a fair price for a Defender 200Tdi? Antichrist Defender Technical Discussions 4 December 23rd, 2008 12:27 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
