Defender 200tdi - Page 2 - Defender Source
Old May 4th, 2016, 02:07 AM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Lift the rover on jack stands on the axles wheels off of the ground.
Hand Spin the driveshaft both front and the rear. Apply the CDL and do the same.
Report the finding as to what spins, driveshafts and wheels..
I feel like it is splines somewhere the drive lines that is not catching.
Old May 4th, 2016, 09:18 AM
the transfer box has a differential in it. It needs to feel resistance from both output shafts in order to work. If something is broken in either axle the truck wont move. Activating diff lock locks the differential and enables the car to be driven on one axle. Applying the parking brake is an attempt to fool it and confirms something is wrong in the rear. If you chock the wheels so the truck cannot move and leave it out of gear and no parking brake on, place the transfer case in neutral, climb underneath and turn the parking brake drum by hand. If you can turn it you have confirmed something is broken in the rear axle. Alternatively you can put the parking brake on and jack up ea rear wheel one @ a time and try turning that wheel by hand.
You indicated that the hub splines are fine, the only way verify that is to remove the snap ring and spacers to check them.
Old May 4th, 2016, 03:18 PM
maria
karen gallo
1992/tdi
worn axle splines from the back of the transfer box which drives the rear prop shaft . i have to reassembly and then give a go i let u know thanks so mach all of u
Old May 16th, 2016, 02:32 AM
Thiemo's Avatar
Thiemo
Thiemo Ebersberger
1989 4 door pick up 110
Sounds like a problem in the transfer box.
Before you rip it apart check that the High/Low are engaged properly. Check the linkage.
Old July 4th, 2016, 08:46 AM
maria
karen gallo
1992/tdi
hi there my defender 110 tdi is always on differential mode i can not get it out of there any suggestions?
Old July 4th, 2016, 06:07 PM
maria
karen gallo
1992/tdi
Old July 4th, 2016, 07:36 PM
First make sure the linkage is rotating the diff lock stud fully. If that is fine, then remove the cover next to the shift rod and check out what is going on. Adjustment and function are explained in detail in the workshop manual.
Old July 7th, 2016, 02:18 PM
maria
karen gallo
1992/tdi
thanks is weekend job let u know cheers
200tdi, defender, tdi
200Tdi/300Tdi Exhaust Mount Locations D90/Disco 200Tdi Conversion edh Defender Technical Discussions 5 February 15th, 2016 05:08 PM
Proper Defender high-turbo 200tdi Defender diesel enigne for sale (Gearbox too) ZombieMotors For Sale - Parts 1 August 19th, 2013 12:02 PM
1983 110 200tdi defender (on new chassis) rovernutzz For Sale - Vehicles 0 December 27th, 2008 12:33 PM
What's a fair price for a Defender 200Tdi? Antichrist Defender Technical Discussions 4 December 23rd, 2008 12:27 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
