Defender 110 with 300TDI - Whining under gear and power - Defender Source
Old March 20th, 2016, 07:55 PM
edcircus
Justin
1984 Land Rover Defender 110
My car has been working well. Iíve had a slow leak of fluids from my front transfer case recently. Iíve been putting it off getting fixed, but now something new is happening. When have the rover in gear and am moving forward, at higher rpmís, no matter what the gear, my rover makes a double whining noise(the one you can hear in the video). The available power to my engine doesnít change nor does any other aspect of the car feedback from driving. The whine doesnít happen when the car is revíd at idle. Iíve tightened most of the hoses, but now believe it has something to do with the transmission or transfer case only because it only happens under power and in gear. It could be a turbo problem I suppose, but Iím just not sure if that would effect the power and/or if it would happen without being in gear. Looking forward to your feedback!
110, 300tdi, defender, defender 110, tdi
Whining and clunking when decelerating? Quimbola Defender Technical Discussions 5 October 9th, 2013 05:48 PM
Howling/Whining Diff 98 HOO Defender Technical Discussions 5 March 4th, 2010 01:32 PM
Feedback/whining noisse thru speakers pmd Defender Technical Discussions 8 May 20th, 2006 12:46 AM
Whining fuel pump? jdb3760 Defender Technical Discussions 16 February 23rd, 2006 02:14 PM
Manual transmission whining shawom Defender Technical Discussions 3 June 22nd, 2005 01:50 PM
