Defender 110 Weak Headlights - Defender Source
Old December 7th, 2014, 07:51 PM
bulldog90
Kenny
1986 110
I have an 86 110 and the headlights are weak - I replaced the headlights but not the issue. Has anyone had this issue
Old December 7th, 2014, 07:55 PM
Ash's Avatar
Ash
Ash Heller
OM606 110 Frankenstein
Pretty common. There's a big loss in voltage from the switch to the headlights so they're likely not receiving 'full power'. The easiest thing to do is to pull power with a heavier gauge wire straight off the battery and to a switched relay that you toggle with the existing headlight wiring. You ought to see an increase in output.
-Ash
Geared Restoration Co.
352-572-3236
Old December 8th, 2014, 06:00 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Old December 8th, 2014, 06:29 PM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
You want:
ARB heavy duty wiring loom
Hella H4 housings
Hella H4 55W/100W "off road use only" bulbs
Details here: http://www.defendersource.com/forum/...d.php?p=580487
The pigtail bits may or may not apply to you, depending on how your lights are wired right now.
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old December 8th, 2014, 11:51 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
This is the simplest method to correct the problem. Yes you do need the ceramic sockets because our stock sockets will burn out.
http://www.ebay.com/itm/H4-Relay-Har...0c2cc8&vxp=mtr
Old December 9th, 2014, 12:45 AM
Also check the grounds. IIRC they or it is on the passenger side inner fender.
Old December 9th, 2014, 07:51 PM
Are they weak as in there is a problem or are they just inadequate. On my '85, the bullet connectors were loose and slightly corroded. Jiggling the connector would make them work normally.
110, defender, defender 110, ht, lights
ECUs are tough, starter motors are weak ini88 Misc. Chit-Chat 8 July 8th, 2010 05:55 PM
300tdi weak acceleration on hills discotdi Defender Technical Discussions 4 July 7th, 2009 09:12 AM
Weak Heater johnpiero Defender Technical Discussions 6 December 11th, 2008 09:07 PM
Weak Idle saber6 Defender Technical Discussions 7 March 7th, 2008 10:35 AM
weak rear brakes? redrover Defender Technical Discussions 12 April 28th, 2006 09:24 AM
