Defender 110 on OC CL CA Registered... - Defender Source
Old April 6th, 2015, 03:52 PM
noeldaniels
Noel Daniels
noe
Hi Guys, was searching on the forum and elsewhere for more info on this 110 CA registered and couldn't seem to find anything...
I'm still in search for a good 110 (i don't mind a little work, but no basketcase) CA registered preferred and surely one that isn't blacklisted or a candidate for Homeland Security attempting to confiscate.
Here's the link... Land Rover Defender 110 California Registered
I've been looking in neighboring states, but it seems to be CA registered already is probably the way to go. Please let me know your thoughts, thanks in advance.
Old April 6th, 2015, 03:59 PM
noeldaniels
Noel Daniels
noe
I'm still in search for a good 110 (i don't mind a little work, just don't want a basketcase) CA registered preferred and surely one that isn't blacklisted or a candidate for Homeland Security attempting to confiscate.
------ Follow up post added April 6th, 2015 03:05 PM ------
oops sorry guys, duplicate thread... thought the first one didn't post.
Old April 6th, 2015, 04:16 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Clifton Scientific Text Services, the Netherlands
CalVIN shows the VIN as a 83 or 84' yet it is listed as a 73' while riding a coiler chassis? Which one or two of the three is not correct?
If this IS titled as a 73', best to stay clear and continue looking.
Old April 6th, 2015, 05:14 PM
Does this mean he stamped a 1973 VIN into the truck and registered it as a Series? - 'The first owner started with the 1973 chassis building from ground up.'
With a bit of searching looks more like a typo ... and it's '83. Also the VIN number in the CL ad is slightly wrong ... the streeing and transmission is I and it should be 1.
SAL Manufacturer code: Land Rover
LD Model: Defender (for early models: Ninety, or One Ten)
H Wheel base: 110 inch
M Body type: 4-door station wagon (LWB)
V Engine type: 3.5 litre V8 petrol, carburettor
1 Steering and transmission: Right-hand drive (RHD), 4-speed manual (LT95, or other)
A Model year: 1983, 1984
A Assembly location: Solihull, UK
211358 Serial number
Old April 6th, 2015, 05:18 PM
noeldaniels
Noel Daniels
noe
I'll look into this and try to see what the deal is...
Old April 6th, 2015, 05:20 PM
noeldaniels
Noel Daniels
noe
OK let me ask him and see what the deal is. I believe he did say this is registered and titled as a '73 but i could be mistaken.
updated my post with more info
use this to decode LR VIN's Clifton Scientific Text Services, the Netherlands
Old April 6th, 2015, 05:24 PM
merged threads
Old April 6th, 2015, 05:28 PM
noeldaniels
Noel Daniels
noe
not looking promising if i remember correctly was registered as a 73, but trying to reconfirm now... thanks guys!
Old April 6th, 2015, 05:36 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
If it is registered as a 1973 but has a replacement chassis that has already been stamped by the CHP, it could be legit.
Old April 6th, 2015, 06:08 PM
noeldaniels
Noel Daniels
noe
Smile
yeah confirmed as well title and reg as '73 and matches up with vin, so with chp replacement stamp this should be okay?
Old April 6th, 2015, 06:12 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Yes but if te seller has not followed the proper procedures for getting it inspected then it's probably not something you want to be getting into.
Old April 6th, 2015, 06:22 PM
noeldaniels
Noel Daniels
noe
By "inspected" you mean with CARB? Or with what agency? Thanks again
Old April 6th, 2015, 06:23 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Chp.
Old April 6th, 2015, 06:25 PM
noeldaniels
Noel Daniels
noe
What would need to get done? Or is it too late?
------ Follow up post added April 6th, 2015 05:30 PM ------
He said he did have a schedule with chp but never went through with it since he was able to title it through dmv, car is currently registered etc. he has never had any issues re-registering over the years. Not sure where to go from here...
Update- just spoke to him in detail and it seems he went through inspection by an agent/rep via AAA dmv in SoCal who vin verified the car and titled it as a '73. Thanks again for your help here...
Old April 6th, 2015, 07:13 PM
Macker's Avatar
Macker
Mack Crouch
1988 110 LS 5.3
Don't take my word for it because I don't know the exact procedure. But I believe it involves showing them the original chassis with the vin still legible and showing them that it's no longer usable and will be destroyed, and showing them a proof of purchase for the new chassis. Again, best to check with a vin officer for the correct procedure. Just be aware that the California Highway Patrol is the agency responsible for verifying chassis swaps, no just the DMV.
Old April 6th, 2015, 07:30 PM
noeldaniels
Noel Daniels
noe
Got it, thanks Mack!
Really starting to think I should really just be looking at NAS Defenders, seems a whole lot easier.
Old April 6th, 2015, 07:35 PM
I see something familiar in this pic! (cough...vents)
Old April 6th, 2015, 09:07 PM
down_shift's Avatar
down_shift
Russell
This truck was in SC before. Probably a Wilmington import.
110, defender, defender 110
Clean California Registered 110...or Big Foot's hiding place whichever is easiest NWL Wanted 0 January 30th, 2015 06:22 PM
'84 D90 300TDI, R380 5Speed, California Registered! robbie For Sale - Vehicles 12 May 3rd, 2011 01:45 PM
Can you get a truck through customs without a registered importer? bitz Defender Technical Discussions 35 July 23rd, 2009 01:24 PM
1974 Registered Series III Hybrid-RHD wlykes For Sale - Vehicles 5 July 23rd, 2009 12:45 AM
How I got a 1990 D-90 Registered Buckon37s Misc. Chit-Chat 14 November 26th, 2003 03:50 PM
