Defender 110 Gear Ratios / RPM's - Defender Source
Old October 28th, 2015, 02:16 AM
brooks1thompson
brooks thompson
none
Hello,
I had a little question about what RPM I am at when cruising. I have a 1988 Defender 110 3.5 V8 with the Lt85 I believe. Its a 5 speed and reverse is way to the left and up. The top speed I have gone is about 70mph and I was just curious what RPM you think that is. Am I close to redline? Is going faster bad for it? Does anyone have an shift chart which gives max speed per gear. Thank you for the help!
Old October 28th, 2015, 06:29 AM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
What size tites do you have? Ashcroft should have a chart on their website
Old October 28th, 2015, 07:55 AM
Originally Posted by Daddymow View Post
What size tits do you have? Ashcroft should have a chart on their website
Fixed that for you
Old October 28th, 2015, 08:08 AM
Loosen your man bra and take a deep breath. You are in no danger keeping your foot on it even after you get to 70. That engine can withstand 6000 rpm and believe me, you'll run out of wheeze with it before you ever top it out.
Old October 28th, 2015, 08:23 AM
LRover's Avatar
LRover
J. Michael McCaig
Depending on tire size and transfercase ratio, 3000-3500 at 70. I have a 1.2 transfercase and 33+ tires and it's about 2900 rpm at around 70
Old October 28th, 2015, 09:26 AM
jafir's Avatar
jafir
Jafir Elkurd
Ashcroft Transmissions - Ratio Calculator
Old October 29th, 2015, 11:12 AM
brooks1thompson
brooks thompson
none
Thank you guys!
110, defender, defender 110
T-Case gear ratios 1.53:1 aka rover Series Technical Discussions 22 February 27th, 2013 03:27 AM
Thoughts on Higher Gear Ratios Wolf Fabrication Defender Technical Discussions 1 February 6th, 2011 02:59 PM
300 Tdi and gear ratios crown14 Defender Technical Discussions 6 December 11th, 2008 09:41 PM
Differential Ratios gearco Defender Technical Discussions 4 January 6th, 2007 12:13 PM
Gear ratios - 1995 NAS Defender? jam90 Defender Technical Discussions 3 February 19th, 2006 03:58 PM
