Defender 110 front shock removal - Defender Source
Old January 22nd, 2018, 04:05 PM
fastinjun's Avatar
fastinjun
Mitch
Replacing front shocks, any tips on getting the bottom nut loose? I've tried a chain clamp etc, no much luck
Old January 22nd, 2018, 04:13 PM
if you plan on throwing out the old shock, i personally would just take a sawzall right through the bushing and pin of the shock body at the top of the bottom spring perch (bottom of the shock body).
I wouldn't even waste the time in trying to remove a rusted nut from a rusted shock that you're planning to throw in the garbage.
Old January 22nd, 2018, 04:22 PM
Naplm00
Matthew
If tossing shocks, big ass slip joint pliers on the shock body. Wrench from underneath
Old January 22nd, 2018, 04:49 PM
fastinjun's Avatar
fastinjun
Mitch
QUOTE=Naplm00;1919527849]If tossing shocks, big ass slip joint pliers on the shock body. Wrench from underneath[/QUOTE] Tried a chain vise grip on that shock and wrench on the nut. Won't budge. Might have to go with the sawsall
Old January 22nd, 2018, 05:19 PM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Impact gun + chain
Sawz-All works too. Been there done that.
Old January 22nd, 2018, 05:48 PM
Naplm00
Matthew
Frankly putting them on is more challenging. Most aftermarket shocks come with full height nuts, this with brand new rubber bushings can be quite the wrestling match for the uninitiated.
I use a bike flat wrench and a jack underneath the swivel ball to keep the shock in place enough to start the bottom nut.
Old January 22nd, 2018, 11:04 PM
fastinjun's Avatar
fastinjun
Mitch
Going to borrow a sawsall tomorrow...and right angle grinder.
Old January 22nd, 2018, 11:05 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Old January 22nd, 2018, 11:10 PM
Pipe wrench on shock body. More than enough torque to snap the shaft if it won’t come undone. Of course oxy is always less trouble.
Old January 23rd, 2018, 08:51 AM
Heat and kroil. I use a large pair of corved jaw vice grips locked onto the body of the shock as low as possible and a long 19mm box wrench. A lot of the time if you melt the nylon in the nyloc nut it will come right off.
110, defender, defender 110
1989 Defender 110 2.5TD, RHD, $35,000 tacthomas For Sale - Vehicles 15 June 28th, 2017 01:11 PM
NAS Defender 110 lrnasd90 For Sale - Vehicles 9 October 29th, 2005 02:01 PM
external front shock mounts? brianbonner Defender Technical Discussions 9 January 11th, 2005 05:06 PM
1993 Defender 110 NAS $39K!! in VA ember For Sale - Vehicles 1 November 22nd, 2004 09:29 AM
How to replace front shocks in Defender? wicks Defender Technical Discussions 8 October 7th, 2003 12:08 PM
