defender 110 build chassis question - Defender Source
Old December 10th, 2010, 03:16 PM
zdover's Avatar
zdover
Darian
1973 109 SIII
Hello,
I am working on a 200 tdi 110 defender build. I am having a problem figuring out where to start with a chassis; I dont want to dish out 4k for a new chassis.. I currently posses three potential chassis I can use: a 109, a 200 tdi 9-90, and a RRC LWB. after mulling over it, I have concluded that the most easy chassis modification would be stretching the d-90 about 20 inches. Modifying the 109 rails with coil perches and new X-members would be PITA but most legal approach to owning a defender with a series title, registration/ paperwork. I have seen series bodies fitted onto a RRC chassis, it requires a lot of fabrication. (lookup gordon's build in florida) None of these chassis are ideal for this build, but what do folx think? Who here has stretched a d-90 frame to 110? Perhaps someone is interested in trading the 90 frame for a 110 chassis.....
Old December 11th, 2010, 01:24 AM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
$4K seems a bit high, I think mine was closer to $3K once I got it here and paid all the taxes. Richards shipped it directly to my door. Any build that you care about, and a 110 should be one, really deserves a new chassis.
Old December 11th, 2010, 01:29 AM
grnrvrs's Avatar
grnrvrs
Paul
88
x2! my Marsland's chassis was just under 3k delivered. Worth every penny.
Old December 11th, 2010, 06:05 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Without having a tape measure to hand, doesn't a 110 chassis have deeper main rails than a 90? (as in, stronger)
stretching a 90 might not be as strong as a proper 110.
Old January 16th, 2011, 01:41 AM
zdover's Avatar
zdover
Darian
1973 109 SIII
thanks for the replies guys.
perhaps I will have to get the measuring tape out and start saving $$ in the meantime. I'm still recovering from what I dished out on a rebuilt 200tdi. perhaps someone here on the forum can offset my cost by buying a nice d90 chassis (so far not chopped). thanks for the references, so far the cheapest quote I've gotten from the UK was 3255.
Old January 16th, 2011, 06:32 AM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Also the distance from the rear axle and the rear crossmember on the frame is different between the 90 and 110 frames. So the 110 tub hangs over further on the back end - decreased departure angle.
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old January 16th, 2011, 08:09 AM
tomaco1's Avatar
tomaco1
T.mac
83 110
Is it a 200tdi chassis?
Old January 19th, 2011, 09:19 AM
zdover's Avatar
zdover
Darian
1973 109 SIII
yes. 200 tdi d-90 chassis.
I've ruled out chopping the chassis. I'm going to try to sell the chassis and buy the 110 or do a straight up trade with someone looking for a 90. I prefer trades
I have not been able to find out if the 200tdi will fit onto a 300tdi chassis' engine mounts
Old January 19th, 2011, 10:59 AM
short answer, no.
Old January 19th, 2011, 11:10 AM
pendy's Avatar
pendy
jim pendleton
89'd90
I think a new rear crossmember with extensions installed on the LWB frame is a good option for you.
legend in my own mind
Old January 19th, 2011, 01:08 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
George @ RDS has new chassis for $3200 already here in the states if that helps!
Old January 19th, 2011, 01:50 PM
Pretty sure it's irrelevant at this point but will mention that I stretched a NAS d90 frame to fit a 109" tub and all the tub mounts had to be re-done.
Originally Posted by pendy
I'm here for the D's
110, chassis 110 90 109, defender 110
Defender 110 build Best4x4 Truck Build-up's & Restores 44 May 2nd, 2010 07:53 AM
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
Another "My Defender won't start" question MiniGuy Defender Technical Discussions 4 December 28th, 2005 12:51 PM
Maybe FS: 1999 Defender 110 Td5 mlepisto For Sale - Vehicles 3 March 18th, 2004 02:17 PM
Rover Build - Rolling Chassis ?s Jase Misc. Chit-Chat 14 March 4th, 2004 10:32 AM
