Defender 110 Backlash in rear diff? - Defender Source
Old August 8th, 2016, 10:30 AM
David@redballs.com
David Vieira
1996 Defender 110
Exclamation Defender 110 Backlash in rear diff?
Hi guys... I have a 1996 Defender 110 that "clunks" when engaged in gear. It has been doing this for years but seems to be getting worse. Is this normal or should I be concerned and try to fix it?... Thanks for your advice... I have a video and photos of the problem if you need to see them to advise...
Old August 8th, 2016, 10:39 AM
Elbee's Avatar
Elbee
Lance
1989 110 200tdi
Might be one of your shafts is worn
Old August 8th, 2016, 10:42 AM
Your video does not seem to work.
If it is from the rear axle only, then I would first check the drive flanges. They commonly wear out, especially in the later axles like yours. The flanges are made of cheese and those axles have seals that prevent lubrication getting to the flange splines.
Old August 8th, 2016, 10:43 AM
Originally Posted by Elbee View Post
Might be one of your main shafts is worn
It is a 1996, so should not have the problem.
Old August 8th, 2016, 11:13 AM
David@redballs.com
David Vieira
1996 Defender 110
Exclamation Thanks!
I'll repost my video...
Old August 8th, 2016, 11:14 AM
David@redballs.com
David Vieira
1996 Defender 110
Any idea what it costs for parts to rebuild the worn shafts?
Old August 8th, 2016, 11:18 AM
Flanges are worn, 90% chance. Pull them off, six bolts, 60 seconds of work with an impact to check. I would just order new flanges now. I seal with RTV but they do have gaskets.
Old August 8th, 2016, 11:37 AM
They are pretty cheap. Might be worth spending more for quality aftermarket ones though instead.
Stock part: Hub Drive Flange (RUC105200 Same Fit As Part # RUC105200 ) - Land Rover hubs from Atlantic British
Upgraded flanges: Ashcroft Transmissions
Please note these later drive flanges are designed to run in a 'dry, non-lubricated' condition and because of this they are prone to the spline wearing from 'fretting / corrosion' leading to failure. They benefit from regular inspection / lubrication.
Old August 8th, 2016, 11:40 AM
Originally Posted by evilfij View Post
....six bolts....
Only for those 1971 "Defenders"
Old August 8th, 2016, 12:03 PM
Another thing to look at is your driveshaft. The U-joints do fail over time and it's clear from numerous posts on here that people don't bother greasing or replacing them.
Old August 8th, 2016, 12:12 PM
Still not working. Seems like you are not attaching a video, but attaching a private link or something.
Old August 8th, 2016, 02:32 PM
Once a series guy always a series guy. Yes, 5 bolts per side on the defender.
Old August 8th, 2016, 03:06 PM
David@redballs.com
David Vieira
1996 Defender 110
I think the video only works on an actual computer not on phones...
Old August 8th, 2016, 03:20 PM
I'm on a computer. It says "video not found or access denied".
Old August 8th, 2016, 03:21 PM
David@redballs.com
David Vieira
1996 Defender 110
Weird... Maybe I'll just post it on Facebook?... Or email it to you?
110, ac, defender, defender 110
Salisbury Backlash How much is Normal? Wilboro Defender Technical Discussions 5 April 13th, 2015 10:08 PM
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Rear diff backlash? TND90 Defender Technical Discussions 2 February 7th, 2010 02:50 AM
Steering Wheel backlash adjustment Mike Finn Defender Technical Discussions 0 December 20th, 2005 12:07 PM
Rockware trailing links, backlash artm Defender Technical Discussions 1 June 14th, 2005 03:59 PM
