defender 110 - Defender Source
Old February 9th, 2016, 11:19 AM
excentric
paul lesson
defender 110
defender 110
my defender has central locking ,immoberliser, movement sensor inside , all working fine but the rear door locks do not go down far enough unless pushed down before you operate the central locking on the key fob , if you do not push them down you can open rear doors which set's off the alarm , any advice would be helpful , thankyou.
Old February 9th, 2016, 11:25 AM
Tonka2's Avatar
Tonka2
Shawn
I had the same problem in my G500 I had to turn the little plastic mechanism to a point that when I hit the FOB it would go down took like a minute or so hope that helps
Old February 9th, 2016, 11:30 AM
phoenix37's Avatar
phoenix37
john
Wow really?...i can't even fathom that kind of technology in my defender. Unfortunately most of us have 25+ year old trucks so not sure many folks here will be able to help..
Old February 9th, 2016, 11:35 AM
You are better off asking on a UK Land Rover forum. This one is mostly USA folks.
Normally, though the linkages are adjustable between lock mechanism and the power lock solenoids. Remove the door card and look.
110, defender, defender 110
Defender 110 :: 1986 Land Rover Defender 110 five door wagon Surfer6955 Defender & Series Truck Registry 8 November 25th, 2015 09:45 AM
Calgary Defender 110 :: 1989 Land Rover Defender 110 Calgarychris Defender & Series Truck Registry 0 July 22nd, 2014 04:46 PM
Defender 110 :: 1984 Land Rover Defender 110 atpick Defender & Series Truck Registry 1 March 14th, 2013 07:19 AM
