Def 200TDI Alternator alternatives - Defender Source
Old September 27th, 2017, 09:18 AM
Vedrover
Alex
1988 Land Rover 110
I will probably need a new alternator for my 200TDI defender CSW and am looking to tap into the shared wisdom of this community.
The current unit is a 70A rebuilt Bosch unit circa 2007. The original unit is a A127/65A (P/N RTC5680N replaced by STC234?). I have a single Optima RedTop battery. I will be eventually installing two winches, a WARN M15 in the front (very soon) and a WARN M12000 in the back (eventually).
Questions:
1) Should I attempt to install a 100A upgraded alternator? There seems to be a mixed feeling about this in the community, mainly because the diesel won't turn the alternator fast enough to get any benefit.
2) LRDirect has the following alternatives for the alternators: Britpart (won't buy); Lucas (says supplied by Britpart, so does this mean it's licensed by Lucas and made by Britpart?); Bearmach and Quinton Hazell. Of this bunch, what's going to last longer and run better?
Thanks!
Old September 27th, 2017, 09:32 AM
OH+D
1972 Series III
I have a variation of the GM CS130 alternator installed on my Defender 200Tdi.
Mine has been upgraded to 160A internals. There are also permanent magnet internals available for the CS130 frame that produce huge amperage from very low RPM.
To fit this alternator I had to clearance the cast steel alternator/PS pump bracket with a grinder by maybe 3/16".
The issue you will run into under very high alternator loads is belt slippage with the V belt. I have not stressed mine to that point yet.
For your situation I'd plan on adding a hand throttle to be able to bump the engine RPM during heavy winching.
Old September 27th, 2017, 09:39 AM
The 120 A upgraded unit Britpart sells works well. I've run one for a few years and no problems. Do not get hung up on the supplier. They all buy the parts from the same factories....
I'm not sure what other ones you are looking at, but that is the only direct fit one. The 100 A alternators for the Disco 200TDI motors will not fit.
Old September 27th, 2017, 09:57 AM
xathor
Nick
98 Discovery
Got a part number for the 120A from Britpart?
Old September 27th, 2017, 10:02 AM
Vedrover
Alex
1988 Land Rover 110
Thanks, is it DA1195 for their current 100A upgrade kit?
I was eyeballing it yesterday actually on their website and my hate for Britpart was battling my realization that no one else offers this option.
Old September 27th, 2017, 10:07 AM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
I have 75 amp alternators for $139.99 shipped for the Defnnder style 200TDI engines.
The alternator is different for the 200TDI disco engine.
Unless you go to a twin belt system, a 120 amp alternator with a single belt will slip under load.
I am running a 149 amp alternator on one of our 110s and had to go to twin belts to stop belt slippage.
About the most you can safely get out of a single V-belt is 90 AMP with the correct geometry.
It is possible to run higher that 90 AMP on a single V-Belt as long as the larger amperage doesn't draw at idle.
RDavisinVA
Old September 27th, 2017, 06:51 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
I have had 2 britpart 100a da1195's fail in just under a year. I think they both had approx 6-8k miles on them. I would run the other way or buy two and carry a spare because you will need it!
Ryan
84 110SW County LHD
07 L322 Vogue
Old September 27th, 2017, 09:35 PM
Vedrover
Alex
1988 Land Rover 110
Thanks, which ones do you have 75A, Bosch or something else?
------ Follow up post added September 27th, 2017 07:39 PM ------
Thanks, that's what I'm afraid of, I don't have much trust in anything complicated, made by Britpart. Ever since I saw their brand new "Heavy Duty" clutch fork fall apart during installation (thank god it was during and not shortly after), I`m very cautious of their quality...
I'd love to get that 70A Bosch alternator that I have right now (the failed one). It's date stamped 2007 so, even with the vehicle not running for a couple of years, it still lasted at least 7-8 years, which is not bad, especially for a rebuilt unit.
Has anyone bought quinton hazell (QH) rebuilt units?
Old September 27th, 2017, 10:29 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
They are new Magneti Marelli made in either Israel, Slovenia, or the Czech Republic.
1 year warranty not counting return shipping for a replacement if needed.
RDavisinVA
Old February 25th, 2018, 10:04 AM
Camp
Chad
How much does that 75amp unit put out at idle? Now that I have my Taurus fan installed, I'm dropping below 12.5v at idle with my A/C on high. That's without headlights on so it will only get worse when it gets hot at night here.
Old February 25th, 2018, 11:50 AM
Naplm00
M
http://www.defendersource.com/forum/...es-126481.html
Here is another direct swap in alternative. It is the 100amp rrc Vogue 4.2 alternator. Modern smaller case design , cheaper than the britpart and you can get it at a local parts store or Amazon if you want . Mine puts out 14.4v at idle
Old February 25th, 2018, 01:12 PM
Holy cow...another awesome find...thanks Matt!
Old February 25th, 2018, 01:20 PM
Naplm00
M
Np dude !
Old February 25th, 2018, 01:37 PM
Camp
Chad
You did great work there and that is certainly on my radar, I'm just trying to discover any other options. Do you happen to know what kind of amperage that unit puts out, with the smaller pulley you swapped on it, at idle? My current unit seems to keep up at speed but idle rpm is too low for it and it struggles with the amp draw. I don't have the tools to measure load on the alternator while running so I'm left with measuring voltage at the battery, which stays anywhere from 12.7 to 13.8 while running at speed. When it was cooler outside, it seemed to keep up at idle but now that it is in the high 70's here in Houston already, I saw the gauge drop lower than it did when I measured mid 12's for voltage.
Some high amperage alternators put out tons of amps at low rpm where others don't have the output until much higher. I don't want to put on a big alternator only to discover it doesn't cover my needs at idle, given that in Houston traffic, idle is where I spend most of my time...
Old February 25th, 2018, 02:05 PM
Naplm00
M
Couldn't tell you , I can tell you that it's is plenty for my highly modified truck
Old February 25th, 2018, 04:11 PM
rdavisinva's Avatar
rdavisinva
Guess Who?
N/A
Depends on demand, but the general rule is 60% of capacity at idle if needed to maintain voltage.
RDavisinVA
200tdi, alternator, tdi
1991 LHD 110 200tdi 5 door greenmountainrover For Sale - Vehicles 4 January 2nd, 2018 06:14 PM
1993 LR90 200tdi. globallandrovers Vendors 1 October 11th, 2006 06:16 AM
def 90 soft top roll cage jeff0409 Wanted 0 February 10th, 2006 06:22 PM
Def front lamp guards wicks Defender Technical Discussions 2 November 30th, 2005 01:31 PM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 09:10 AM
