Deep water wading with the NAS clutch cover - Defender Source
Old March 13th, 2013, 01:18 PM
sro
Sam Odio
2008 LR2
I was replacing the clutch over the other day and I noticed that it doesn't seem to be watertight. For example, there is not very much pressure on the top edge of the clutch plate.
Nothing is holding it vertically, so my slipped down a fraction of an inch during installation, creating what seems to be a very small crack between the top of the clutch plate and bell housing.
Has anyone had this problem before? I was thinking about applying some RTV sealant (avoiding the small drain hole of course) and re-seating the thing.
Old March 13th, 2013, 02:47 PM
Hard to follow what you are asking. The "clutch plate" is the friction disc. Are you refering to the bell housing to block fitment, or the small access cover ? It is not meant to be water tight. Given the signifigant swings of temp inside the bellhousing an air tight seal would be a bad idea. The bell housing has a removable "wading plug @ the bottom. This is to be removed after a deep wading to release water that has managed its way in.
Old March 13th, 2013, 02:59 PM
sro
Sam Odio
2008 LR2
Sorry, yes not the clutch plate but the clutch cover (that attaches to the bell housing). Brain fart.
It seems like a significant amount of water, sand, and mud could get in there during water crossings. Mine doesn't have a removable plug (just a very small hole at the bottom).
So, I just shouldn't worry about mud/sand getting into this thing? It seems like RTV sealant around the clutch cover would prevent most ingress while at the same time the drain hole would allow for breathability during temp changes.
One of the reasons I ask is because the clutch plate recently failed (at the Pismo Sand Dunes no less) and I'm wondering if this might have been the cause...
Old March 14th, 2013, 08:04 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
On Series Rovers the wading plug (a 1/4" pipe plug) is installed before wading, then removed after, to help keep water out. The wading plug came from the factory screwed in to an 'L' shaped bracket attached by one of the bell housing bolts.
Provided you keep it removed during normal operation I can't think of any reason it would be bad to seal the bell housing.
If you do that, it's good practice to do the typical Series "modification" and move the bracket to the dash so there's never any question in your mind if the plug is in the flywheel housing or not.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
clutch, cover, nas, water
Rubber transmission tunnel cover for a '95 NAS D90 dnp Wanted 6 January 27th, 2012 06:07 PM
NAS Alternator, Tire Cover steinhnj For Sale - Parts 2 September 25th, 2011 04:15 PM
Is this the right fan clutch for a 94 D90 NAS? EnduroPro Defender Technical Discussions 3 May 29th, 2010 03:58 PM
Spare Tire Cover (Stiffback?) Wanted D90JMUR Wanted 3 September 29th, 2005 05:36 PM
deep water fording rover4x4 Misc. Chit-Chat 8 October 28th, 2003 08:56 AM
