Death wobble on tape - Defender Source
Old March 1st, 2016, 12:18 AM
lrna04's Avatar
lrna04
Michael
1994 D90
Accidentally hit a pothole at 65mph and caught the steering "death wobble" on video. https://youtu.be/RPeYzYjgv1g
Old March 1st, 2016, 12:23 AM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
That was pretty mild.
Proud member of the YCHJCYA2PDTHFH club.
My mechanic told me, "I couldn't repair your brakes, so I made your horn louder."
Old March 1st, 2016, 12:26 AM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Glad you landed it! Good work. Better with 4 wheels than 2!
Old March 1st, 2016, 02:47 AM
Time to toe out your tires!
Old March 1st, 2016, 07:01 AM
Ohlins's Avatar
Ohlins
Retired Weirdo
1986 Army 110
That happened to me a couple of times in Ulster..those Northern Irish roads can be a bit rough...turned out to be the Panhard rod bushes.
Hope you get the problem sourced.
All the best
200tdi Ex British Army 110 Hardtop 139142kms
2.286 Petrol Series 3 Lightweight 75,043kms
3.2DiD Pajero 266,000kms
Yamaha XTZ660Z Ténéré 58112kms
Gas Gas 300EC Ohlins Enduro Moto.
Old March 1st, 2016, 07:56 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You have 1 or more of 4 causes...
The Joints on your steering shaft have come loose or are worn out and possibly some or most of your suspension bushings need to be replaced.
While you're at it check the swivel ball play and remove shims as needed.
Check for play in the steering box and adjust as needed.
Get her done.
Danger Will Robinson, get out the wrenches...
RDavisinVA
Old March 1st, 2016, 07:59 AM
lrna04's Avatar
lrna04
Michael
1994 D90
I have castor correction bushes, new drag link and damper going in next week. But it's apparent I have about 1" of play from the steering box, so add that to the list.
The 2" lift messed with the toe in and I hope that gets sorted out with the new bushes. But the tire wear and this DW confirm its too toe in right now.
Old March 1st, 2016, 08:25 AM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Bushings won't have any affect on toe in/out.
Old March 1st, 2016, 09:57 AM
Matt_110's Avatar
Matt_110
Matt
110
Check your steering stabilizer. My guess is that it needs to be replaced
1987 110, 2.8TGV, ZF Auto
Old March 1st, 2016, 10:51 AM
Fix it first and then replace the steering stabilizer.
It is a common misconception that the stabilizer's job is to dampen these vibrations.
Old March 1st, 2016, 10:57 AM
lrna04's Avatar
lrna04
Michael
1994 D90
I have a few front end things to sort out.
1 loose wheel bearing
2 bent draglink
------ Follow up post added March 1st, 2016 11:01 AM ------
Originally Posted by lrna04 View Post
I have a few front end things to sort out. 1 loose wheel bearing 2 bent draglink
I going to attempt measuring most of the steering geometry before and after.
Old March 1st, 2016, 11:44 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
God I drove a disco with this issue and seriously thought I was going to lose it on the highway.
I wouldn't even drive it until its fixed, you can be severely compromised as speed and losing control in a 90 is horrifying
Old March 1st, 2016, 12:24 PM
Mine was ultimately caused by a shock that had a soft spot in the compression ... or that was a result of underlying issues ... but basically i replaced everything on the front end to get to the bottom of it.
Old March 1st, 2016, 02:02 PM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
Mine was the pretension in the swivel balls, I also changed most of the front end, it's been good ever since. Mine would start at 45 mph. That was scary enough. At hwy speed? Holy crap!!
Old March 1st, 2016, 04:03 PM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
I battled this same problem on and off for over 4 years. It finally came to a head at last years MAR. I did a moderate trail ride on Saturday and couldn't drive over 20 mph back to camp without the front end going apeshit. It turned out to be the panhard rod (the bushings were only 6 weeks old). Luckily Charlie and Skinny Pete came to the rescue.
See the last photo on this page: 2015 Mid Atlantic Rally (MAR) Review
Here's a thorough, methodical troubleshooting process from a fellow member: http://www.defendersource.com/forum/...ion-33943.html
Old March 1st, 2016, 04:11 PM
taoseno's Avatar
taoseno
Todd Kendrick
1995 D90 #2206 Original Owner
Mine was swivel balls and/or drop arm..............
Todd
'95 D90 #2206
'66 109" P/U
Old March 9th, 2016, 02:50 PM
ITALY2AMERICA
Zachary Hoyt
88 D90 CSW
jumping on the discussion. I got my '88 D90 about 3 days ago. I have noticed that there is about 2-3" of play in the steering wheel between left and right at low speeds, and that at high speeds I don't get what sounds like a death wobble per se, but a slow rhythmic pulling left and right. It is not violent and is controllable, but it just seems like the truck doesn't want to go in a straight line at highway speeds, particularly when on a downhill grade. I visually inspected the ball joints, as directed by another member, and there was no play in them, but then again, I don't really know what I'm looking for. any help is appreciated!
Old March 9th, 2016, 02:57 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Sounds like your front alignment is tow out preventing straight tracking.
RDavisinVA
Death Wobble Eradication Davis Defender Technical Discussions 33 May 30th, 2015 02:27 PM
Fiery Death Wobble Wranglers! waveridin1959 Misc. Chit-Chat 3 March 22nd, 2012 04:33 PM
Death wobble..WTF?? MudD1 Defender Technical Discussions 11 June 23rd, 2010 11:03 AM
Steering stabilizer... Death Wobble.. TDI Guy Defender Technical Discussions 13 September 15th, 2008 12:27 PM
Death wobble saga kellymoe Misc. Chit-Chat 4 February 12th, 2005 05:12 PM
