Death clip ! - Defender Source
Old December 12th, 2012, 08:51 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Death clip !
Yep, that's the name for that little bugger on a french LR forum.
I'm talking about the little piece of crap that holds the clutch slave cylinder pushing rod to the clutch fork.
How do you get it back in his place without having a nervous breakdown ?
Cheers
- Charles Eames
Old December 12th, 2012, 01:15 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
There are two kinds and one requires someone with long skinny fingers. Good luck. I wasted better part of a day once.
____________________
Chris Hinkle
Current project - D110 with extended cab and LS3
Old December 12th, 2012, 01:18 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
Easy, just remove the engine, and then with a 10mm spanner you can undo the clip, re-insert the pushrod, then refit the clip....
....then refit the engine... :-(
Old December 12th, 2012, 01:20 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
Cheers
this gent made up a clip holder...
http://forums.lr4x4.com/index.php?showtopic=62274
Old December 12th, 2012, 02:24 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Found a few interesting things:
- Charles Eames
Old December 12th, 2012, 03:20 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
I can imagine you laughing while typing this haha
Robert Deniro
D90 finds death in Val Borbera (Jan outing) Cube II Trips, Trails and Events 4 February 22nd, 2006 02:59 AM
Lift question beaten to death again...... gonewheeln Defender Technical Discussions 6 July 6th, 2005 06:57 PM
RoverRollOver Clip... norros Misc. Chit-Chat 11 May 17th, 2005 01:37 AM
Death of a T-Case flippedrover Defender Technical Discussions 14 May 21st, 2004 07:28 PM
ST rear window clip! TwisteD90 Wanted 2 November 12th, 2003 11:53 AM
