dealership is screwing me... - Defender Source
Old September 30th, 2013, 03:08 PM
masfas2000
brian masin
2003 discovery
I took it to the dealer, knowingly...that it was going to be outrageous and now looking for other options. i have read a number of the posts and here in the northern virginia area i have decided to go with loudoun rova. I dont know if it is bad business for me to buy the parts i need offline and bring them in to have the shop install them?
If so, does anyone know of a shop in NOVA that allows that? i had meineke install a full exhaust system that i bought offline...cost $500 cheaper, but this isnt exactly a mustang...
So the dealer says i need a new evap pump and gas cap, front drive shaft joint, rear driveshaft flex and that my headgasket and front cover are leaking.
The rover has no marks under it ever that would suggest it is leaking anything.
thoughts?
Old September 30th, 2013, 03:10 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Are you using coolant?
Are you talking about the Discovery in your profile or a Defender? What year and engine?
Old September 30th, 2013, 03:14 PM
Really? Do you bring your own eggs and bacon to Denny's?
Old September 30th, 2013, 03:18 PM
masfas2000
brian masin
2003 discovery
http://www.partsgeek.com/catalog/200...rge_valve.html
$90
http://www.carpartsshed.com/Catalog/...e=8%20Cyl.4.6L
$96
i dont know if the front and rear drive shafts are the same thing or not...a few sites has them coupled together.
------ Follow up post added September 30th, 2013 01:21 PM ------
no i dont bring my eggs...
hey, i own my own company and people bring me things all the time that i could charge more for because i have them in house, but i dont...i just charge them for the mailing fee.
It is a 2003 discovery se7
not leaking anything...not losing coolant that i can tell
------ Follow up post added September 30th, 2013 01:22 PM ------
it is a v8
Old September 30th, 2013, 03:23 PM
get a second opinion ... or ask him why he has come to this diagnosis.
Do you have CEL on?
Old September 30th, 2013, 03:24 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Well here are those two parts cheaper from us - http://landroverparts.roversnorth.co...=PLD196&type=0
http://landroverparts.roversnorth.co...px?code=PLN901
And there are shops that let you bring your own parts, but some will add a bit extra to the labor rate, some won't.
Old September 30th, 2013, 03:25 PM
masfas2000
brian masin
2003 discovery
What is CEL?
Old September 30th, 2013, 03:26 PM
Check Engine Light.
Old September 30th, 2013, 03:28 PM
masfas2000
brian masin
2003 discovery
yes, it wont pass inspection here in virginia because of the check engine being on.
Old September 30th, 2013, 03:36 PM
You need oxygen sensors. That will turn off the check engine light. The rest of it I would only fix if they ding you at the emissions place.
Old September 30th, 2013, 03:40 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
if you are just getting the safety inspection then buy a code reader and erase the code before you take it in for inspection.
masfas2000
brian masin
2003 discovery
what does it cost to get oxygen sensors installed?
Old September 30th, 2013, 03:42 PM
1of40's Avatar
1of40
1of40
prob 1/100th of the time it would take you to do it X the shop's rate
Old September 30th, 2013, 04:09 PM
Oxygen sensors are about a hundred bux each. I think you need four, but I may be mistaken on that particular year. They install with a 17mm box wrench. Or is it a 19mm. I forget.
Old September 30th, 2013, 05:53 PM
O2 sensors aren't going to fix your defective DMTL pump, or your gas cap that doesn't thread down completely.
Everything they listed wrong with your Disco are very common problems.
Old September 30th, 2013, 06:06 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
So, let's try to resume this: You took your Disco to a place to get looked at because it is failing inspection or emission? My truck passes inspection with a CEL being on.
So, I think you have two goals:
- pass emission testing (where the CEL needs to be off and functioning)
- pass inspection testing
One a little less important goal
- get your truck/engine/etc running as optimally as possible.
I would ask the shop to classify what goes in which category so you know what you -have- to do vs. what you should do soon.
I think the gas cap is likely an emission item (my D1 had to get a new gas cap at the last testing). But don't take my word for it, get the shop to tell you.
Likely the engine leak is neither emission not inspection. Not sure how your truck/engine, but I have heard many stories of D1 V8 4.0L being misdiagnosed with headgasket issues where "only" the valley pan gasket needed to be replaced (granted once you are doing the valley pan, easy to so the rest and easier to explain to anyone that does not turn wrenches).
2 cents!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old September 30th, 2013, 07:12 PM
Probably have it done by the time you've finished reading this thread.
Old September 30th, 2013, 07:25 PM
smob's Avatar
smob
Steve
'97 Arles Blue SW #2131
Agree with Bill 100% - change 02s and then run the truck for 10 minutes on the highway before you go in. Works like a charm for me. Do other emissions work only if required.
As for places in NOVA that will take your parts, Loudoun Rova and Arlington Motorcars will do it sans extra cost. I'd personally choose AM before LRova.
-Ren Ching
Old September 30th, 2013, 08:28 PM
MonLand
Loic Fabro
Originally Posted by smob View Post
Arlington Motorcars
Literally across the street from the dealership (across rt
7 that is).
MonLand
1995 D90 NAS
1996 Discovery NAS
wing
LR Dealership in Northern NJ -- need help! jefhuf Misc. Chit-Chat 8 April 8th, 2013 08:59 PM
Dealership signs remarkart The Flea Market 2 October 5th, 2012 10:06 PM
Land Rover Anckorage Alaska Dealership T-shirt jack frisch For Sale - Parts 2 February 25th, 2005 09:18 AM
Check Engine Light after I was screwing around with fuses... P1CR Defender Technical Discussions 3 April 1st, 2004 04:56 PM
Opening a Dealership wicks Misc. Chit-Chat 30 March 4th, 2004 11:57 PM
