dealership is screwing me... - Page 3 - Defender Source
Old October 1st, 2013, 02:03 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Originally Posted by masfas2000 View Post
the check engine light needs to be off for 200 miles or so before the station will accept it as fixed...so i cant just hook up a tool to reset.
Not sure if that was clear or not: you will need to fix the problem(s), reset the light and drive your truck until all the monitors are "ready".
This apparently seems to take 200 miles? That's seem a lot to me, can't see the shop drive your car for 200 miles before taking the emission testing; takes 10-15 miles on my D1 including highway speed driving to get everything ok. But maybe you're right. I have zero D2 experience myself.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 1st, 2013, 04:12 PM
Since when is the purge valve bad? I thought it needs an "EVAPS pump" which would be the DMTL pump. Why don't you post up the repair order so we can see what is actually wrong with the vehicle.
Old October 1st, 2013, 04:15 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
He posted this up needing the part - http://www.partsgeek.com/catalog/200...rge_valve.html
Old October 1st, 2013, 06:05 PM
He also asked if the front and rear driveshafts are them same, I doubt that's what he's looking for unless he was told he needs a purge valve.
Its likely that he has a P0455 which is caused by the defective DMTL pump. The threads on the gas cap are probably also tight which will prevent the gas cap from being fully tightened down.
Old October 1st, 2013, 06:48 PM
discotdi
Todd Miller
Land Rover
well i am not a doosh that would blame the dealer if they fixed my car and then something went wrong...by saying they are screwing me is when i looked online at typical costs for fixing items on a land rover, they were over $4k more just on the labor costs. Then on the parts, assuming that i buy everything required, they are another $1k. So to say that the dealer is screwing me is pretty accurate. The big ticket item on the bill was the headgasket, which it looks like i dont need to get done according to most of you, at $6k...the labor on that is overt $4k.
Everything i have read it looks like i just need to get the evap fixed for now and the rest can wait. The evap at the dealer is going to cost $400, which isnt bad in my mind, but i am figuring that all they are going to do is put on a gas cap and call it a day.
Well it seems that you are paying for their expertise since you don't know how to repair the truck yourself. If you are looking online for typical pricing after you took it to the dealership seems you are a bit late. Pick it up from the dealer and take it to one of the online experts. If you don't like the prices that one place charges then go somewhere else, but don't say they are screwing because you don't agree with the prices they charge. BTW all genuine LR parts will cost you much more than non genuine. Most non franchise stores will use non genuine parts.
they are only screwing you if they charge you and don't repair it properly.
Not sure how the title for this thread was derived. You got a diagnosis that you can (and already have said you intend to) take else where. How did they screw you ?
Old October 1st, 2013, 06:58 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
True.. I was just suggesting an alternative. 75% of the D2s I've made acquaintance with have had to replace the purge valve. I suppose at least I had a basis for the reasoning, 02 sensors were suggested for no reason on the thread haha.
Old October 1st, 2013, 08:17 PM
I agree with you, they definitely fail frequently. I'm just guessing he has a P0455 which is why they would have recommended the gas cap and DMTL pump. A purge valve will usually set a P0441 or P0442 in my experience.
Old October 1st, 2013, 09:06 PM
masfas2000
brian masin
2003 discovery
the work order says i have a faulty evaporator valve and fuel cap
Old October 1st, 2013, 09:42 PM
I have never heard of an "Evaporator valve." I'm sure that's the service writer being an idiot and not knowing what he is talking about. I'm guessing then you need a purge valve, and a gas cap.
Old October 1st, 2013, 09:51 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
P0441 is what I see as well for the purge valve, I believe they had a service campaign for the gas cap issue as well?
Old October 1st, 2013, 09:56 PM
The service campaign was probably to prevent technicians from putting on gas caps for a P0455 without any further diagnosis. Under warranty, it would pay about 1.5 hours to diagnose, replace a gas cap, and verify the repair.
Old October 1st, 2013, 11:33 PM
couga861900's Avatar
couga861900
Cougar, WM of Hiram 72
Land Rover Defender 90 2.5td
Did you think of going to the Auto Zone in the area of the inspection and have them reset the check engine light/computer for free and drive straight to get inspected? You would pass if the light is not on and then get the problem fix somewhere reliable and cheap with a new emission sticker. Just Asking
Old October 1st, 2013, 11:36 PM
jafir's Avatar
jafir
Jafir Elkurd
Didn't some need a fuel filler too?
Old October 2nd, 2013, 12:47 AM
masfas2000
brian masin
2003 discovery
tried that already...when i took it back to the station he told me that once it is fixed i need to drive it 200 miles...while that is excessive, va inspection has something in place to prefej you from doing what you suggested
Old October 2nd, 2013, 06:21 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Originally Posted by o2batsea View Post
Thanks Matt, but I do OK despite my weak mind.
Bill, I know that. You are well versed, and I apologize if you took this as an insult of some sort.
I'm just tired of the " I read on the internet that it needs O2 sensors", when in reality much (most) of the time the O2 sensors (once tested) prove to be fine and are doing their job of telling you that the fuel management system is for what ever reason unable to maintain a mixture that falls within pre-set adaptive parameters, and one or more of the inputs that help define this is missing or out of range......pretty simple really and ripe for some proper diagnostics rather than generalized assumptions.
My "internet research / reality conversion matrix", is almost complete.
Matt Browne
Old October 2nd, 2013, 08:16 AM
Its also worth noting that probably 70% of the time its just oil in the connector rather than the o2 sensor being bad.
Old October 2nd, 2013, 07:36 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Now you no to never take it for emissions when the CEL is on.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old October 2nd, 2013, 09:30 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
NORTHERN va inspection has something in place to prefej you from doing what you suggested
The rest of VA is pretty lax...
Ask me about inspections in the valley.
Rent my
Old October 3rd, 2013, 04:59 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Come to think of it, I'm surprised they even hooked it up with the CEL on.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
wing
LR Dealership in Northern NJ -- need help! jefhuf Misc. Chit-Chat 8 April 8th, 2013 08:59 PM
Dealership signs remarkart The Flea Market 2 October 5th, 2012 10:06 PM
Land Rover Anckorage Alaska Dealership T-shirt jack frisch For Sale - Parts 2 February 25th, 2005 09:18 AM
Check Engine Light after I was screwing around with fuses... P1CR Defender Technical Discussions 3 April 1st, 2004 04:56 PM
Opening a Dealership wicks Misc. Chit-Chat 30 March 4th, 2004 11:57 PM
