Dead tachometer... - Defender Source
Old January 20th, 2008, 10:14 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Exclamation Dead tachometer...
Needs some help???
Posting this before I purchase a new tachometer, not sure if it's really dead or not. Recently replaced my alternator & now my tachometer is not working. Could replacing the alternator zap a electronic device? Before the tach stopped working it did have somewhat of a bounce, bounced mostly when you applied pressure to the break. Or could it just be poor timing?
Thanks for your help in advance,
Weldon
Weldon
Old January 20th, 2008, 10:48 AM
The tach lead comes off of the alternator - are you sure you connected all the right leads to the right terminals? If I recall correctly, the alternator lead is marked "w." A possible issue could be that the connection at the terminal was weak before you replaced the alternator, and now the wire has severed or something. The issues are directly related.
Old January 20th, 2008, 02:02 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Jim,
Thanks... It was the connection, once again thanks.
Weldon
ac
darn! my ac is dead! =( scubadanster Defender Technical Discussions 16 August 2nd, 2005 05:32 PM
HELP, HELP Dead D90 in CT januconn92 Defender Technical Discussions 16 July 8th, 2005 08:20 PM
Need a DEAD EFI computer for parts Hans Wanted 0 December 5th, 2004 03:21 PM
Water pump pulleys - got a dead 3.9 laying around? jaherring Wanted 3 September 9th, 2004 09:16 AM
d90 dead 4 hours from home! head gasket? vesparover Defender Technical Discussions 4 August 17th, 2004 04:47 PM
