Dead Battery...maybe? - Defender Source
Old November 15th, 2004, 12:17 PM
Antonios
Antonios Hadjigeorgalis
No more
I was out of the country for 2.5 months and forgot to disconnect my battery. (red top optima)
Now it won't hold a strong charge, but I haven't driven it too much either. Does anyone know if there is a set amount of time needed to run the vehicle so that the battery gets fully recharged? How can I tell if it's shot and needs to be replaced?
Thanks in advance for any tips.
1994 D90 #359
Old November 15th, 2004, 12:44 PM
Take it to autozone, they will test the battery in the car for free!
Old November 15th, 2004, 12:49 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
1994 D90 #359
You would have been better off if it was a Yellow Top, which is designed for deep discharge (see: http://www.optimabatteries.com/publi...l#000100010017 )
The two things batteries hate are sitting discharged for periods of time, and heat.
You may want to use a charger to try and top off the charge in the battery. Charging info is on http://www.optimabatteries.com/publi...cal_specs.html
Old November 15th, 2004, 01:22 PM
Antonios
No more
Well I took it autozone and they told me it was shot, then I had to jump start it to get home so I think I'll believe them.
Miami, FL
Old November 15th, 2004, 09:26 PM
try a very slow trickle charge. That usually sales optimas. If it is within three years old free replacement on red tops
Old November 15th, 2004, 09:43 PM
Antonios
No more
We did you get the info on a free replacement? Mine won't be three until May.
Miami, FL
Old November 15th, 2004, 09:51 PM
http://www.optimabatteries.com/publi...anty_info.html
Old November 15th, 2004, 10:17 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
"You would have been better off if it was a Yellow Top, which is designed for deep discharge (see: http://www.optimabatteries.com/publ...ml#000100010017 )"
This is absolutely wronge. Optimas suck hard. I have been through 5, yep 5. Both red and yellow. The yellow lasted a huge 5 months. They died exactly how Antonios batteries did. Only buy an optima if you drive the truck every day, or if you hate yourself.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 16th, 2004, 02:11 PM
My sits for extended amounts of time not 2 months, perhaps a month or a month in a half I have had no issues with mine. Its the red top
Old November 16th, 2004, 09:19 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
your lucky
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 16th, 2004, 09:24 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
Leaving any lead-acid battery in an uncharged state for an extended period of time is abuse. The plates get sulphated, which is difficult to reverse. The yellows can take a deep discharged, but they still must be charged up again within a short period of time.
Old November 17th, 2004, 10:41 AM
lobster's Avatar
lobster
Rob Goodall
1995 D90
Optimas do suck! They never recharge fully after being drained. Get rid of them.
1995 D90 ST
1999 Super V8
battery
Battery Light/Tachometer Intermittant markurski Defender Technical Discussions 9 June 21st, 2009 09:18 PM
Battery Compartment under seat Flagg Defender Technical Discussions 11 May 15th, 2007 11:38 AM
Sealed battery? OCD90 Defender Technical Discussions 4 December 22nd, 2003 01:43 PM
