dazed and confused . . . - Defender Source
Old September 3rd, 2015, 11:24 AM
wanabewheelin's Avatar
wanabewheelin
Michael Sword
1989 110 200TDI, RHD
discovered a sizable oil leak from the oil pan. Have done them before on other vehicles so was up to the challenge on the defender. Wasn't quite as easy of a job, but got er done. Let it the RTV set 24 hours before adding oil, then added oil, started it up and leaked from the rear of the motor. Got "the right stuff", cleaned and degreased and repeated the procedure.
Again, leaking from the rear of the engine.
Throw myself on the mercy of the court, don't claim to be an expert in all things mechanical, car related or not. Just need some expert help here, looked to be a thin gasket that runs vertical up the back of the engine. (2.5TD 19J) also looks like there might be a slight gap on one side, but can't get or see any bolts on that side (this would be the clutch housing yes? My 110 is a RHD, so this puts it on the passenger side of the truck (normal driver side).
Kinda shotty pics, last one is from the first go around. First 2 are from last nights failed attempt.
thanks in advance for any assistance!
ID:	128662   Click image for larger version
Old September 3rd, 2015, 11:26 AM
ezzzzzzz
Mark Garrenton
It's engineered in for rust prevention.
Old September 3rd, 2015, 11:38 AM
Not sure exactly what you are seeing, but there is a gasket between the block and the clutch housing and it certainly can and does leak from there.
Old September 3rd, 2015, 11:46 AM
Sorry, I was wrong. These may use an o-ring or just sealant to seal that spot, not that it helps to know...
Old September 3rd, 2015, 11:49 AM
wanabewheelin
Michael Sword
So need to drop transmission to get to the back of the block and replace the o-ring ??
Old September 3rd, 2015, 11:53 AM
Yes. The manual says later engine all use sealant, so I "assume" all TDs are considered later.
File Type: pdf Pages from Land Rover 90-Workshop-Manual-1991.pdf (37.1 KB, 19 views)
Old September 3rd, 2015, 12:08 PM
wanabewheelin
Michael Sword
Ok NOVA fellas, anyone up for a wrenching party need to get this biatch back on the road
Old September 3rd, 2015, 12:37 PM
I agree. You really should not get a "sizeable" leak from the crank as it is above the oil level. Oil level is correct? Crankcase breather is working?
If you do end up pulling the engine, you are going to want to seriously consider doing all clutch and throwout parts as well unless they have a known age. I'm not normally one to suggest shipfitter's disease, but it sucks when the throwout fork punches through a week after you pull the engine.
Old September 3rd, 2015, 12:47 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Sounds like Skinny P should take a look.
Old September 3rd, 2015, 12:51 PM
wanabewheelin
Michael Sword
sorry for the confusion, pulled the pan, cleaned all of the RTV off, degreased and reapplied "The right stuff" last night.
believe the leak is coming from the "O"ring seal, have a slight gap between the rear of the engine and the flywheel housing.
from the manual that Red90 provided it shows in "Later engines" . . . in place of the "O" ring seal a bead of Hylogrip 2000 (RTV) sealant must be applied to the rear face of the flywheel housing (5.5mm wide x 0.25mm thick) see illustrations.
should be a fun weekend.
Red90, do you happen to have a link to the rest of the manual?
Old September 3rd, 2015, 01:08 PM
pdf Land Rover Manuals | Landroverweb.com
See the "Defender 90 & 110 Workshop Maunual" in multiple parts. It is the 1991 manual covering up to 200TDI.
Old September 3rd, 2015, 01:35 PM
Indeed!
Where in DC is this vehiculo located?
Present:
1960 SII 109"- "Red Square"
1984 90 Tdi- "Yamelo"
1988 RRC- "Chewbacca"
1987 RRC- "Chewy 2"
2008 RRS SC- "The Supersofa"
Past:
Old September 3rd, 2015, 01:49 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
I was going to say, you have a lot of good guys with a lot of knowledge and talent in your area.
Old September 3rd, 2015, 01:57 PM
wanabewheelin
Michael Sword
Originally Posted by Ren Ching View Post
Indeed!
Skinny Pete, I'm in Annandale, right off 236 by Northern Virginia Community College.
cell is 703-599-4322
Old September 3rd, 2015, 02:15 PM
oh, you need a visit from the PeDroMobile™
Thought you were in DC
Present:
1987 RRC- "Chewy 2"
Past:
Old September 3rd, 2015, 02:21 PM
wanabewheelin
Michael Sword
wait, thought we were talking about people with knowledge about LR's
Old September 3rd, 2015, 02:31 PM
Yep, you're by the legendary dro...and HH actually.
Do you have a hoist and/or tranny jack?
Old September 3rd, 2015, 02:38 PM
87 D110 (Ruby)
oh he has met the 'Dro...
Old September 3rd, 2015, 02:57 PM
wanabewheelin
Michael Sword
unfortunately no on both the hoist and jack.
Dro is very close and has been over to the house to see the LR before, just not lately
Old September 3rd, 2015, 03:23 PM
bottom line, if you can slide the thinnest feeler gauge in between the block and the flywheel housing, you have a problem and need to pull the engine or the trans. they should be in contact with each other.
otherwise, you need to decide how bad the leak is and live with it, or pull the engine and do a full clutch and rear main seal job.
Present:
1987 RRC- "Chewy 2"
Past:
totally confused..torsion clutch pedal spring Rufus Defender Technical Discussions 10 January 14th, 2014 01:18 PM
Confused about oil pressure sender. VDO replacement sundogcwolfe Defender Technical Discussions 3 May 20th, 2010 06:24 PM
Constantly confused by bolt materials fenwaystan Defender Technical Discussions 7 August 24th, 2009 12:10 PM
Spedometer out - :confused paulb Defender Technical Discussions 2 October 31st, 2006 09:08 AM
Confused... sflash868 Defender Technical Discussions 3 September 30th, 2006 08:39 PM
