Daytime running lights??? - Defender Source
Old November 7th, 2003, 03:59 PM
terreneuve
1997 D90
Exclamation Daytime running lights???
Does anyone have a schematic for wiring daytime running lights module to a 1997 NAS D90 ??
Any help appreciated!!
Old November 7th, 2003, 04:18 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Talking
Three easy steps
1. Reach out with your left hand.
2. Grasp switch between your thumb and first finger.
3. Turn light switch on.
Why on earth would you want to????
I have spent considerable time trying to disconect a ford p/u's daytime lights.
Old November 7th, 2003, 04:29 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
Read your profile...sorry about the smartass comment.
Do you have to have them for regestration in the Great White North.
Rover sold d-90s in Canada and should be wired from the factory.
Old November 7th, 2003, 04:31 PM
terreneuve
1997 D90
Very funny you should give up your day job and become a comedian!!!!!
To title a 1997 D90 in Canada it has to have operational daytime running lights, if not I would not have them either!!!
Thanks for your stupid answer though!
Old November 7th, 2003, 04:52 PM
terreneuve
1997 D90
Apology accepted, sorry for the smart response back but it was a serious question.
Part of the importation inspection in Canada requires a daytime running light module to be installed and I don't want the LR dealer mechanic here to touch it has he has never seen a NAS D90 let alone work on it!!.
If someone is to screw it up I would like it to be me!
D90 were only sold in Canada in 93/94 and I understand that the
computer used in 1997 may be different and I do not want to set the computer in a "testbook" rage by fiddling with wires.
Brgds
terreneuve
Old November 7th, 2003, 05:00 PM
mhansen's Avatar
mhansen
Mike Hansen
97 D-90 SW #2243
John-
You should be able to wire in a relay the same as you would wire aux lights. the only difference would be that the switch hot wire would be connected to a (ignition on) source like a radio, or dash light circut, and the hot out from the relay would be spliced into the headlight low beam wire.
I arn't no 'lectrision or nutin but that is what i would try.
Also Canadian rovers should be wired for day time lights, and thus there should be a wiring diagram out there somewhere.
Old November 7th, 2003, 05:05 PM
terreneuve
1997 D90
Thanks Mike
Old November 7th, 2003, 05:43 PM
Don't know how electricly incline you are so I found this pin out on a standard relay you can use.
Currently the relay that turns on your headlights has that switch if you jump or short out that switch it would make the headlights come on all the time. Be carful not to jump or short the parking light part of the switch because the parking lights will stay on with the 90 is turned off.
If it were me I would try to come up with a way to add cheaper lower wattage lights to the headlamp enclosures to be used as your Daytime lights that way you don't burn up your headlamps and you are not using as much power. I think newer cars do this, you can tell by watching them when they turn their headlights on and it gets brighter then daytime head lights.
So, the fastest and cheapest way is to just pull your headlight switch out and short the 2 connectors that turn the headlights on and they will be on whenever the engine is running.
Name:	relay pinout diag.jpg
Old November 8th, 2003, 02:42 PM
terreneuve
1997 D90
Thanks Mike
I am no electrical guru but understand the principles, also a case of beer will get me a leckie and a mechanic (beer after they work!!) to assist should need be.
I am also waiting for a Factory workshop manual from a friend as maybe the truck is wired for daytime lights already and just needs a relay or some type of adapter as I don't like chopping at wires for no reason!!
Old November 11th, 2003, 02:12 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Hi John-
My Newfs said "Hello". They keep telling me that they want to go home someday.
Once you get the workshop manual, you can confirm this, but I think that all you have to do is add a relay. My Wife wanted the DRLs on her Disco and the dealer said they could do it by adding a relay.
Also, when I was looking at D90s, I looked at a Canadian 94. Yep, it had DRLs.
Chance
Old November 11th, 2003, 09:32 AM
terreneuve
1997 D90
Thanks Chance
I don't have a workshop manual yet but I could not find any reference in the parts manual I have.
Great looking Landseers you have , we had a black female up until 5 years ago but unfortunately she died at 8 yrs of age.
Old November 11th, 2003, 12:28 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
I just remembered that I've got the CDs for our Disco and I think the D90 stuff is on there. I'll check tonight. I just have to set my clock on the PC back so that I can access them...
Thanks! Ahhh yes, they don't live nearly long enough. We lost our boy (Cousteau) at 5.5 this past May. Our female (Chamonix) is doing great at 7.5.
Chance
Old November 14th, 2003, 12:45 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Sorry for the delay, but my PC crashed. Stupid Winblows. I looked through them and saw nothing about DRLs. Sorry. However, the schematics will tell you where to hack in a relay. Anyway, I captured the entire section on exterior lights for you. It's attached. Good luck!
Chance
Old November 14th, 2003, 10:22 PM
terreneuve
1997 D90
Thanks Chance
I am away noe but will look into when I get back.
ht, lights
Side and Running Lights Question ronward Defender Technical Discussions 3 July 24th, 2006 06:57 AM
Hinged fog lights. rustydefender Defender Technical Discussions 2 February 28th, 2005 09:33 PM
DS Running light? Eric Siepmann Defender Technical Discussions 1 June 27th, 2004 07:55 PM
Clear lens for running lights PT94D90 Defender Technical Discussions 5 April 9th, 2004 07:28 PM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
