Davis Unified Ignition - Defender Source
Old December 13th, 2011, 04:32 PM
spartan's Avatar
spartan
Fred
83 D110
My ignition module is bad so I ordered a new distributor. I called Mallory and MSD. They both recommended I purchase Davis Unified Ignition 96920RD.
http://www.summitracing.com/search/Y...?Ns=Rank%7cAsc
I did a search on this forum but did not find any info on this distributor. I did not buy it from Summit Racing since its a 2 week lead time. I ordered one from http://www.performancedistributors.com/ 3 day lead time.
Anyone know about this? Its a old Buick/GM small block style distributor. It has the coil built-in.
Old December 13th, 2011, 05:05 PM
You can repair your Lucas ignition module with some wiring and a $30 GM ignition module.
Old December 13th, 2011, 07:41 PM
James Pierce's Avatar
James Pierce
James Pierce Jr.
I would do some more research. I believe the DUI is not worth all the hacking required to make it fit. I read somewhere it requires grinding on the intake / intake bolt? Genuine is still the best IMO.
Old December 13th, 2011, 08:26 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
Do mallory.
Robert Deniro
Old December 13th, 2011, 09:33 PM
spartan's Avatar
spartan
Fred
83 D110
I was going to buy Mallory but they suggested DUI.
Removing Faulty Ignition Switch - It's STUCK rijosho Defender Technical Discussions 20 March 29th, 2017 12:54 PM
Ignition? Trigger Defender Technical Discussions 12 August 1st, 2005 08:53 PM
Ignition Power bjenk Defender Technical Discussions 9 November 22nd, 2004 07:20 PM
different ignition options vesparover Defender Technical Discussions 5 December 5th, 2003 03:02 PM
