Dash removal - Defender Source
Old November 14th, 2012, 12:29 PM
Grover's Avatar
Grover
Question Dash removal
I will be doing some repair work to my bulkhead vent handles and I need to remove the grey(ish) vent cover to do so. Looks like it is fastened with plastic button snaps.
Any tricks for removing this?
Cheers...
Old November 15th, 2012, 09:40 AM
Grover's Avatar
Grover
Bumpity bump...
Old November 15th, 2012, 09:57 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
You just pop most of them out with the "Y" tool...but I find that more than half will need to be replaced.
jefferson's Avatar
jefferson
Jeff A
97 Defender 90 SW #593
Mike - It is connected with plastic push-in trim pins that will likely need to be replaced when you re-install. I found suitable ones at AutoZone. The more of the upper dash you remove, the easier it will be to get that grey plastic cover out. I found that I had bend it considerably to get it to clear the vent handles - I thought it was going to break, but it was surprisingly resilient. Getting it back in was no easier - you just have to patiently work it into place.
Old November 15th, 2012, 10:24 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Actually just did this with the old mans 90. The pins arent that expensive, so just order them up from RN. Remove the side piece then unscrew the top two screws on the binnicle, one on each side. Then there are two screws along the underside edge of the top dash pad that hold the lip of the grey piece in place. Also unscrew the all the screws along the top of the top dash pad, should be 3 big screws and four screws that hold the cover for the vent pieces. Mine were very brittle (the pins) so I just snapped the heads off.
Then its just a matter of carefully manhandling the grey piece out. Should be about it.
dash
LHD Dash CDeWan For Sale - Parts 32 October 3rd, 2012 05:03 PM
Upper dash removal lraker Defender Technical Discussions 4 June 21st, 2012 12:40 PM
Dash Rotted Out, Had to Fix It JimC Misc. Chit-Chat 7 February 6th, 2009 03:20 PM
1997 Dash panel - what's there? ronward Defender Technical Discussions 6 April 26th, 2004 05:47 PM
Dash Removal pcarey Defender Technical Discussions 8 March 6th, 2004 11:32 PM
