Dash Removal - Defender Source
Old March 1st, 2004, 03:39 PM
pcarey's Avatar
pcarey
Peter Carey
'93 NAS Defender 110 #322
Dash Removal
I'm going to be getting a manual really soon, really!
But in the mean time, does anyone have any pointers to removing the lower dash section on a 110 in order to put in some light switches? I've looked at it a couple times and assume you just remove every screw you can find, including the heater vents underneath, and it will magically come off.
Are there any hidden items I should look for? And is there anything to the right of the steering column that would interfere with putting in the switches?
thanks
pwc
Old March 1st, 2004, 04:05 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Peter, there are screws behind the plastic covers for the air vents under the windshield so you have to remove them first and get the screws there too. Remove the front plastic edge around the parcel tray and the tray itself.
Legend in My Own Mind.
Old March 4th, 2004, 08:51 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Peter,
Not sure if you got this done or not, but I have an NAS 110 and the dash is apart right now so I could probably get info for you if you need it.
Old March 4th, 2004, 09:12 PM
pcarey's Avatar
pcarey
Peter Carey
Ryan,
I was hoping to get to it this weekend so if you have any info, I'd appreciate it. Or even just a picture with it removed so I understand what's behind it would be perfect.
thanks for the offer.
pwc
pwc
Old March 4th, 2004, 09:40 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
It's been a while since I tore into my dash, but I think it's easiest to work top-down. Remove the upper dash first, remove the side panels, remove the driver's instrument panel, remove gray plastic fascia (probably the most difficult part due to attached ductwork that gets caught on things from behind). I've never removed the lower dash, and it doesn't sound like you'll need to if you're just looking at installing some switches. I'vel attach some pics for the area I think you're concerned about. You shouldn't have any problem if this is where you're looking to install the switches.
Old March 4th, 2004, 09:41 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Inside
Old March 6th, 2004, 03:23 PM
pcarey's Avatar
pcarey
Peter Carey
Thanks Ryan,
I've got the top and sides off but there seem to be a number of screw that your can only get to through the vents to get the gray fascia thingy off. That sound about right?
Once I get that off, I can get to the other part without taking it off to put the switches in.
And where the heck is the dang Service Engine reset box? I was told it would be behind the instrument panel but I only see three boxes and none are it. I had a RRC before and know what the box looks like, but these all have different descriptions on them.
hmmm
pwc
pwc
Old March 6th, 2004, 08:57 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Yup. Sounds like you've got it right. The gray plastic fascia is a pain to remove. I don't remember exactly how I did it, but I think I had to remove some of the vents to get at the screws. And you need to be careful not to break them. Just keep looking for hidden screws. Oh, and if you haven't already, you'll need to remove the heater control lever plastic ends so the fascia can slide past.
As far as the Service engine box goes, I remember it being behind the instrument panel. I got rid of mine so it's no longer there.
Old March 6th, 2004, 11:32 PM
pcarey's Avatar
pcarey
Peter Carey
I still couldn't find the box so I'm just going to swear there isn't one. Thinking back, I should have cut the wire for it but it's not that big of a deal and adds some color to the dash.
There was also the screw holding the gray part to the box the instrument panel is in. That one had me for a bit.
Alas, there wasn't room behind where I wanted to put the switches and settled with putting them on the top of the dash because of their depth, 2 on either side of the ash tray. I'm not overly happy with my work and there are now two poke holes where things slipped and went where they shouldn't. It's not horrid but it's also not the best job in the world either. That's something I will have to put on my tombstone...
thanks again for the pointers Ryan.
pwc
pwc
dash
Revmoving lower dash on LR 90 gregorw47 Defender Technical Discussions 8 November 23rd, 2011 06:12 AM
Dash Rotted Out, Had to Fix It JimC Misc. Chit-Chat 7 February 6th, 2009 03:20 PM
New Defender Dash parts TDI Guy For Sale - Parts 1 April 3rd, 2005 10:58 AM
Stereo Install In Dash caschumann Defender Technical Discussions 18 November 4th, 2004 12:41 AM
1997 Dash panel - what's there? ronward Defender Technical Discussions 6 April 26th, 2004 05:47 PM
