Dash Lights Vanished! - Defender Source
Old November 13th, 2003, 10:34 AM
dalesmith71's Avatar
dalesmith71
Dale Smith
'95 D90 ST, AA Yellow
Unhappy Dash Lights Vanished!
Yesterday evening I got in my truck, cranked it up, turned on the lights and noticed that it was awfully dark in the cab. It seemed that my dash lights decided to cut out, yet every external light (and the dome light) all still worked. Furthermore, the clock still runs and all of the gauges are operational. This morning I checked the fuses and they all appear good. Is there a fuse or relay that's not on the main fuseblock that I don't know about? Any help would be much appreciated!
Dale
Scouts Out!
Old November 13th, 2003, 11:07 AM
Check the Dimmer switch to the left of the wheel, the plug on the back can fall off.
Old November 13th, 2003, 11:19 AM
dalesmith71
Dale Smith
I tried flipping the switch, but I didn't check the connection. I'll give it a shot at lunch. Thanks, Mike.
Dale
Scouts Out!
Old November 13th, 2003, 06:36 PM
dalesmith71
Dale Smith
No luck, the switch was still connected.
Dale
Scouts Out!
Old November 13th, 2003, 06:59 PM
man i cant get mine to go out
Old November 13th, 2003, 07:25 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
In both cases it sounds like a relay issue. Trace the positive wires back to the source and test the relays.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 13th, 2003, 09:23 PM
dalesmith71
Dale Smith
Philip,
It's not the warning lights, it's the lights for the gauges, clock, and heater/defroster switches. My warning panel actually works like it should.
Dale
Scouts Out!
dash, ht, lights
dash lights out rmuller Defender Technical Discussions 5 February 10th, 2008 10:56 PM
Dash Lights shawnpalmer Defender Technical Discussions 11 March 21st, 2007 03:13 PM
Dash lights a floating bulb paulb Misc. Chit-Chat 5 February 14th, 2007 07:21 PM
Brakelights turn on dash lights - stupidest electrical problem ever JimC Defender Technical Discussions 7 October 18th, 2006 06:21 AM
dash gauge lights very dim Marc Weinstein Defender Technical Discussions 15 October 17th, 2004 01:49 PM
