dash lights out - Defender Source
Old February 2nd, 2008, 07:59 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
dash lights out
Was working on hooking up a VDO temp guage today and was having an issue with a light.. so while I was in there I was testing with a test light and hit the wrong lead apparently and all of the dash lights for the gauges blew out. Checked the fuses, and no issues there, checked the relays I could find (under the fuses, and a 'bulb check' relay under the dash) and they were fine. The switch still works to illuminate the head lights and the lights (headlights, check engine, etc..) lights are working fine.. It really seems as if I blew a fuse, but I can't figure out where.. Any ideas?
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old February 2nd, 2008, 11:11 PM
LenB's Avatar
LenB
Len Bruffett
NAS '97 ST /SW-POE Config
Hi Ryan,
I don't know about '94s But On my '97 the fuse that manages the left side running lights (side markers, tail and front) also manages the interior gauge lights. Check and see if those lights are out as well. Check your fuse map and find the left side running light fuse - you may have missed it in your hunt for the blown fuse.
Len
Old February 3rd, 2008, 11:56 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
FYI: This happen on my truck!!
Anyways, you got the story from Ryan. Today I put in the new VDO gas gauge and obviously no lights still (I didn't expect them to work, but at least I put the gas gauge in). When I flick on the headlights, all dash lights are out, including, Hazard, Clock and Cigar lighter. The speedo and Tach work because they are mechanically fed. But the new gas gauge is out. it won't read the gas that is in there. So is this a blow fuse or relay? Where can i find this fuse or relay?
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old February 4th, 2008, 12:20 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Have you also checked the underhood fuse bank, next to the brake cylinder?
My oil line fix
My 100k stopped odometer fix
Old February 4th, 2008, 12:23 AM
rmuller
Ryan
Yeah, there were 4 of the large 30amp fuses there.. one was labeled 'lighting' .. I checked them all and they were all fine...
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
Old February 10th, 2008, 10:56 PM
rmuller
Ryan
Originally Posted by LenB
Hi Ryan,
Len
This was actually it! It was a little 7amp fuse, first fuse on second row of fuses on the dash... I missed it on my first initial test, but we noticed that the left side running lights and tail light was out and traced it back to this one.. Thanks Len
Ryan
Current:
2001 Discovery II
2006 LR3 HSE7
dash, ht, lights
Dash lights kennybahr Defender Technical Discussions 9 February 16th, 2008 03:55 PM
Dash Lights shawnpalmer Defender Technical Discussions 11 March 21st, 2007 03:13 PM
Dash lights a floating bulb paulb Misc. Chit-Chat 5 February 14th, 2007 07:21 PM
dash gauge lights very dim Marc Weinstein Defender Technical Discussions 15 October 17th, 2004 01:49 PM
Dash Lights Vanished! dalesmith71 Defender Technical Discussions 6 November 13th, 2003 09:23 PM
