dash lights - Defender Source
Old September 29th, 2010, 09:33 AM
PDX Bolt
Tom Harbolt
1995 White D90 Soft Top
dash lights
Just drove my 95 d-90 ST at night for the first time in a long time. My faint recollection is that the tach and clock used to be illuminated. My other guages are illuminated, but the tach and clock are not. Can someone tell me if their's are (so I know what normal is), and if they should be illuminated (and they are not) should I be checking fuses or what to get them illuminated. Sorry in advance for the rambling question.
Old September 29th, 2010, 09:41 AM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
both should be lit. Check the bulbs first.
Old September 29th, 2010, 02:11 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
All of the lights in my gauges were piggybacked from one another so I assume you have a bulb problem. Also may want to double check the ground leads
Old September 29th, 2010, 02:31 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
Even when they're lit,they're not really 'lit', take this chance to swap in brighter bulbs/LEDs.
Old September 29th, 2010, 03:54 PM
the_eaze's Avatar
the_eaze
Eric Brown
1997 Arles SW
Whats the best place to get the LED's from?
Old September 29th, 2010, 04:11 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
heard good things about http://www.superbrightleds.com
Old September 29th, 2010, 04:15 PM
Reese_D90's Avatar
Reese_D90
Reese
I got mine from superbrightled.com as noted above.
Here is what I ordered for my 97 ST D90-
Exterior:
count / location / part # / comments
2 Front Parking & Signal, Amber 67-A9
2 Front side marker, Amber WLED-A6
2 Rear side marker, Red WLED-R6
2 Tail/brake, 1157-R24 wide
4 Front and Rear Signal, 1156-A24 wide
1 Back up (reverse), 1156-W24 wide
2 License Plate, White BA9S-W4-12V
1 Flasher Relay for LED, CF13GL-02 (this goes in the dash fuse panel. There is an ECR link earlier in this chain)
2 Load Resistors RL-650 (I needed one for each front blinker, connected in line right behind the bulb socket)
Interior:
2 Fuel & Temp, WLED-G6
3 Tach and heater and blower lights, 74-GHP3
2 Speedo, B8.5D-G (see photo)
1 Dome light, 1156-cw18-t
I didnt change out the clock bulb
The LED make a huge difference on the interior lights. I now have to turn mine down in brightness. Not that big of a change to the exterior lights.
Old September 29th, 2010, 09:56 PM
GMFett's Avatar
GMFett
Marcus
1994 D-90
Reese- were the interior lights easy to swap out?
Old September 29th, 2010, 10:24 PM
Reese_D90's Avatar
Reese_D90
Reese
10 min. tops
the time was making sure i ordered the right parts. I just changed the interior lights in my SW this weekend. I think with shipping the total was $24. Shipping was 1/2 of the cost. Let me know if you want to get together some time and crack open the dash and see if the bulbs are the same in a '94
Old September 29th, 2010, 10:45 PM
KKilo23's Avatar
KKilo23
Kenny
Reese what color did you get for the interior lights? How do they look compared to OEM?
Old September 30th, 2010, 12:28 AM
Reese_D90's Avatar
Reese_D90
Reese
Green. They really are 3 or 4 times brighter than the stock bulbs. I had to turn down the lights with the dimmer switch.
Old September 30th, 2010, 08:01 AM
PMKColorado's Avatar
PMKColorado
Paul Koentges
'95 White D-90, #2625
dash lights
also check to see if your dimmer toggle switch is fully connected. Mine was working loose and caused a similar problem.
Old September 30th, 2010, 10:27 AM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
delete
Old September 30th, 2010, 10:31 AM
PDX Bolt
Tom Harbolt
Thank you
You guys are amazing. Thank you for all the help. I will go take a look, but I don't believe my 95 has a dimmer switch. Nevertheless, I will order the LEDs
Old September 30th, 2010, 11:03 AM
PMKColorado
Paul Koentges
yes, you should have a dimmer toggle switch (two total) on the left side of steering wheel lower dash . It dims the dash/instrument panel, not by much however. If yours doesn't dim, it's either unplugged or has been modified. One of mine controls my rear worklight.
Old September 30th, 2010, 11:15 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
If you order the miniature wedge base bulbs (74-GHP3) make sure that you snip the wires on each side. The wires wrap around to meet each other on the opposite side. I installed mine and it melted the cable in 5 seconds. I have no idea why they would ship them with the wires wrapping around like that. Did you have this problem, Reese or did you have the foresight to snip them before installing? All 74x LED bulbs are like this.
http://www.superbrightleds.com/cgi-b...ini-wedge.html
Old September 30th, 2010, 11:49 AM
GMFett's Avatar
GMFett
Marcus
1994 D-90
Anyone know if the bulbs on the 94 and 95 are the same? If not- Reese- it'd be great to get together and compare bulbs.
-Marcus
Old September 30th, 2010, 01:10 PM
Reese_D90's Avatar
Reese_D90
Reese
-Marcus
I am not sure they are the same. I think the speedo bulbs are differnt. I will post a picture tonight of the bulbs I took out.
Old September 30th, 2010, 09:55 PM
Reese_D90's Avatar
Reese_D90
Reese
Here is a picture of the stock bulbs I replaced in my '97 ST and SW. No issues at all. Are these the same in '94 and '95s?
Left to right is Speedo (it takes 2 bulbs); Fuel and Temp (one bulb each); Tach and heater and blower lights (one bulb each)
2 Speedo, B8.5D-G
The second photo is the 74-GHP3 that replaces the smallest bulb. It has an LED on each side and one on the top. Manimal, this is the one you mentioned cutting the wire. These done have any wires that I can see. It has a bead of lead on one end of each side that make the connection with the plug instead of a wire like on the stock bulbs. ???
Old October 1st, 2010, 12:35 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I got the 74G for the dash. As you can see in the pic there is two wires on each side. Should be fine once snipped but I haven't done that yet. I got a little hesitant after i fried the cable. I have yet to replace the dash bulbs so I can't yet confirm the fit or what bulbs are stock.
I also got the WLED-xLX for the side markers (amber in front and red in rear). Really bright LEDs. I'm very happy with those.
dash, ht, lights
dash lights out rmuller Defender Technical Discussions 5 February 10th, 2008 10:56 PM
Dash Lights shawnpalmer Defender Technical Discussions 11 March 21st, 2007 03:13 PM
Dash lights a floating bulb paulb Misc. Chit-Chat 5 February 14th, 2007 07:21 PM
dash gauge lights very dim Marc Weinstein Defender Technical Discussions 15 October 17th, 2004 01:49 PM
Dash Lights Vanished! dalesmith71 Defender Technical Discussions 6 November 13th, 2003 09:23 PM
