dash lights - Defender Source
Old April 25th, 2010, 03:00 PM
matansas
jon lyons
97 AA Convertible
dash lights
my lights behind my tach and temp gauge went out this weekend. book says remove fours screws and replace bulbs. Is it really that simple.
Old April 25th, 2010, 04:06 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
No, they're lying, you actually have to pull the dash away from the bulkhead to get to the bulbs.
Yes, it is easy! be careful though when you pull the dash away that you don't pull out any of the wires, and depending on whether you'rs is electonic speedo or the old mechanical cable, you'll have to unplug the (mechanical) cable if it is (usually a white squeezy connector thing on the back of the speedo head)
Old April 25th, 2010, 04:16 PM
PMKColorado's Avatar
PMKColorado
Paul Koentges
'95 White D-90, #2625
dash lights
check that the dimming rocker switch is plugged in; left side lower dash...the lights won't work if unplugged. You can get to the dash lights by removing the 4 outer screws then pulling of the speedo cable...good luck
dash, ht, lights
dash lights out rmuller Defender Technical Discussions 5 February 10th, 2008 10:56 PM
Dash Lights shawnpalmer Defender Technical Discussions 11 March 21st, 2007 03:13 PM
Dash lights a floating bulb paulb Misc. Chit-Chat 5 February 14th, 2007 07:21 PM
dash gauge lights very dim Marc Weinstein Defender Technical Discussions 15 October 17th, 2004 01:49 PM
Dash Lights Vanished! dalesmith71 Defender Technical Discussions 6 November 13th, 2003 09:23 PM
