dash gauge lights very dim - Defender Source
Old March 15th, 2004, 11:39 PM
Marc Weinstein
Marc Weinstein
defender 90 '94
lights illuminating gauges are very dim! (although brighter since new alternator installed)should I replace control switch?-seems to do nothing as far as brightness control is concerned. Any feedback appreciated. Marc
Old March 16th, 2004, 12:39 AM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
My instruments are pretty dim too. It could just be a Defender thing. I know old CJ's and my neighbor's FJ40 all have dim gauges.
Old March 16th, 2004, 06:33 AM
Berty's Avatar
Berty
Brett Hurrell
D90 Hardtop 300Tdi
Marc, they are pathetically dim as standard . You can replace the bulbs with slightly higher wattage variants. You need to be careful though as anything over 5W (I think) will melt the lampholders & wiring.
In the UK a few people are replacing the bulbs with LED's. Coloured for extra Bling!
There is a thread in the International forum over on LRE from a couple of days ago with more details.
Sniff my Diff ;)
Old March 16th, 2004, 09:22 AM
If you can read them then they are OK, if you can't then the switch may have come disconnected. The part of the dash the switch is on comes off with easy, just 3 screws.
Old March 16th, 2004, 10:16 AM
Berty's Avatar
Berty
Brett Hurrell
D90 Hardtop 300Tdi
further to my earlier post 5W bulbs will melt the holders & wires!
So don't use them!
The LED's to fit are the 501 bulb replacement type. Wide angle.
The white LED's will make your dials appear ice blue
www.ultraleds.com
Look under car 12V led bulb replacements.
Old March 16th, 2004, 10:24 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Also, there is a "dim" switch depending on year that is located to the left of the steering column. My 94 has this and it took me quite some time to realize why my lights were so dim. Flicked the switch and vawalla!
Old March 16th, 2004, 10:29 AM
elaborate on the LED's, are they just plug and chug, or is there furthur alteratation needed in order to accomadate them???
Old March 16th, 2004, 10:30 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Any one know if there is US seller of the LED replacement lights??
Jimmy Buffett
Old March 16th, 2004, 10:31 AM
flippedrover
Tyler
'94 D-90
From what I read on the site it looks like plug and chug.
Jimmy Buffett
Old March 16th, 2004, 10:43 AM
mpodgorski's Avatar
mpodgorski
martin
'94 D90 ST Arles
this is a large US distributor for LED lighting
they will have what you are looking for, http://www.ledtronics.com/.
Old March 16th, 2004, 11:01 AM
You may want to check out the Auto-Parts store, they have LED replacements around here that all the "ricers" use.
Old March 16th, 2004, 11:31 AM
Berty's Avatar
Berty
Brett Hurrell
D90 Hardtop 300Tdi
Phil, they are plug & chug
You will need 4 off.
2 for the speedo, 1 for fuel & 1 for temp. If you've got a rev counter or clock, you'll have to have a look yourselves
Old March 16th, 2004, 11:59 AM
Link to LRE Thread
Old March 16th, 2004, 01:01 PM
artm
Arthur Maravelis
97 SW
My 97 has the switch and on high the lighting is very bright. I always keep it low so the bulbs last longer.
Since apparently this is also in 94's, I'd take it out and check it.
Old October 16th, 2004, 10:52 AM
Marc Weinstein
Marc Weinstein
defender 90 '94
Any one in the US have the correct led part#'s for dash gauges, and has anyone done this to a NAS d-90, all positve stuff on UK sites. Marc mdw168@aol
Old October 17th, 2004, 01:49 PM
Defender50th's Avatar
Defender50th
James
'94 NAS AA Yellow
Hello,
I have LED's in my Defender 50th Anniversary which is basically a 1997 NAS.
The dial bulbs you need are:
Spedo: 2 x 509T Twist Fit Standard Led Dash Bulb
Fuel: 501
Temp: 501
Rev counter: 286 Dash Board Slim wedge bulb
I replaced mine with white bulbs and they look great (sorry havent got a pic).
Just make sure the bulbs have the same brightness or they will look odd.
i think my dials are the same as a NAS, pic atached to compare:
Best regards
James
dash, ht, lights
dash lights out rmuller Defender Technical Discussions 5 February 10th, 2008 10:56 PM
H4 retrofit lens/bulb combo = dim lights! jaherring Defender Technical Discussions 1 January 18th, 2005 12:37 PM
Moving Dim Lights.... Eric Siepmann Defender Technical Discussions 3 November 22nd, 2004 11:46 AM
Dim Instrument Panel Lights gearco Defender Technical Discussions 2 June 20th, 2004 11:29 PM
Dash Lights Vanished! dalesmith71 Defender Technical Discussions 6 November 13th, 2003 09:23 PM
