dash bulbs - Defender Source
Old November 7th, 2005, 12:58 AM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
dash bulbs
I need a couple of bulbs, maybe you can help.
The bulbs are for a 97 Defender SW.
They are both dash bulbs. I need one or two that lights behind the speedometer, and one green bulb that lights behind the heater fan control on the right hand side of the steering wheel.
I canít seem to be able to find these anywhere.
Any help or suggestions?
Old February 17th, 2011, 10:26 AM
JRW's Avatar
JRW
94 D90 ST #1247
Anyone know a source for these bulbs in OEM green? or an LED replacement?
Thanks!
bjf -> Go to
and build a new defender.
phoenix37 -> If only it were that easy...
Old February 17th, 2011, 01:41 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
I have done the interior led switch in both of my trucks.
this tread has all the led part numbers from superbrightleds.com
http://www.defendersource.com/forum/...&highlight=led
here is a link to that speedo bulb on their site.
http://www.superbrightleds.com/cgi-b...specs%2FB8.htm
Old February 18th, 2011, 12:04 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I highly suggest switching all the stock gauges to VDO before you convert them to LED. Once you upgrade to LEDs you are going to realize how crappy the stock gauges are at transmitting the light. They reflect the light very poorly even if it is well lit. The VDO gauges light up like modern gauges where the needle is also lit.
There two bulb types needed for the VDOs. I can list those here if there I'd interest.
Old February 18th, 2011, 11:53 AM
JRW's Avatar
JRW
94 D90 ST #1247
Trust me I know. I upgraded my Temp gauge since I was having issues and am annoyed at the different intensity.
So when you do the upgrade, what about the Speedo? Are you running up the milage?
Back on topic...I ordered the bulbs from Rovers North. Something like $1.30 per.
bjf -> Go to
Old February 18th, 2011, 02:29 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Depends on the LED bulb you get. Did you get high powered LEDs?
Old February 18th, 2011, 03:09 PM
JRW's Avatar
JRW
94 D90 ST #1247
On the speedo, I was referring to the odometer.
bjf -> Go to
Old February 19th, 2011, 09:54 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Doesn't matter. Just saying that there is a big difference in light intensity between standard and high powered LEDs. If you have high powdered ones I can understand that they would be too bright. Standard ones shouldn't be.
Old February 20th, 2011, 12:56 PM
JRW's Avatar
JRW
94 D90 ST #1247
Roger.
When I replaced the Temp gauge, I stayed with the standard (Non-LED) bulb). Since I went to the VDO vision series, the light through-put is much better than the standard gauges. I wonder if the high intensity LEDs would even out?
bjf -> Go to
dash
led replacement bulbs for dash gauges Marc Weinstein Defender Technical Discussions 75 October 21st, 2017 03:52 AM
NAS 110 - Dash Gauge Bulbs - Green pcscharfe Defender Technical Discussions 15 September 20th, 2010 12:53 PM
Dash Rotted Out, Had to Fix It JimC Misc. Chit-Chat 7 February 6th, 2009 03:20 PM
Stereo Install In Dash caschumann Defender Technical Discussions 18 November 4th, 2004 12:41 AM
1997 Dash panel - what's there? ronward Defender Technical Discussions 6 April 26th, 2004 05:47 PM
