Dash bulb replacement - Defender Source
Old November 14th, 2007, 12:14 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I can't seem to find this info anywhere but does anyone know what size bulbs fit in various parts of the dash? I believe 194 wedge bulbs are what I need for the gauges. Is this correct? Do all the gauges use the same bulb? Most importantly, what size bulbs fit the various switches such as the rear wiper switch, hazzard switch, defroster and heated windshield switches?
Thanks!
Old November 14th, 2007, 06:41 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Bump...Nobody has any info to share?
Old November 14th, 2007, 08:20 PM
texasdefender110's Avatar
texasdefender110
T.J. D...
NAS Defender 110
When I replaced the hazard and rear defroster switch bulbs I used the 1.2W bulbs, RTC3635, from Atlantic British. I'd guess the bulbs are also available from other sources. I have not needed to replace any of the gauge bulbs, so no help there.
T.J.
Fightin' Texas Aggie Class of 1998, Whoop!
Old November 14th, 2007, 09:09 PM
howd you replace the bulbs in those switches?
Old November 14th, 2007, 09:16 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I was thinking that is probably what they used but I really appreciate you confirming it for me!
Old November 15th, 2007, 12:04 AM
texasdefender110
T.J. D...
NAS Defender 110
I replaced the bulbs by gently prying the switch covers off with a flat blade screw driver. Removed and replaced the bulbs with needle nose pliers with cloth taped to the jaws for cushion; its a tight fit. Pushed the switch covers back on.
Old November 15th, 2007, 12:21 AM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
Andrew,
Do a thread search under dash or LEDs. Several threads on replacing the bulbs with these.
Mine is a mess with half the lights out. On the short list..
I'm contemplating thinking about thinking about it!
ac, dash
led replacement bulbs for dash gauges Marc Weinstein Defender Technical Discussions 75 October 21st, 2017 03:52 AM
Dash lights a floating bulb paulb Misc. Chit-Chat 5 February 14th, 2007 07:21 PM
Need mini dash bulb light replacement Doug Young Defender Technical Discussions 8 January 27th, 2005 07:02 PM
Side Marker Bulb Replacement Matt Klapmust Defender Technical Discussions 8 December 23rd, 2004 06:09 PM
Instrument light bulb / Sylvania replacement Mark M Defender Technical Discussions 2 November 17th, 2004 04:23 PM
