darn! my ac is dead! =( - Defender Source
Old July 26th, 2005, 10:57 AM
scubadanster
daniel park
1997 defender 90
hey gang,
my 97 SW ac doesnt work anymore....was working perfectly fine just the prior day...
any thoughts??? any would be much appreciated!
thanks...
hot as heck,
-dan
Old July 26th, 2005, 11:10 AM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
Does the compressor turn on? Does the cooling fan in front of the condenser run? What doesn't work?
Old July 26th, 2005, 11:45 AM
I'm with Dave, it's the flux capacitor that needs recharging, I could sell you some plutonium but you would need to pick it up as I have been having problems with shippers lately.
J/K we need a little more info to be able to help it could just be a stupid fuse.
Old July 26th, 2005, 12:13 PM
scubadanster
daniel park
1997 defender 90
lol....thanks fellas....
how to check?? i am so not a mechanic!
-dan
Old July 26th, 2005, 01:00 PM
Turn on the AC, open da hood and look at the AC compressor (from the front it is on the top left of the engine), the center section of the clutch should be turning. There is also a electric fan that should come on, it is infront of the radiator and you can see it by looking through the grill it too should be spinning. What exactly isn't happening? Does it blow air, is the air cold?
Old July 26th, 2005, 02:20 PM
Originally Posted by Mike Hippert
There is also a electric fan that should come on, it is infront of the radiator and you can see it by looking through the grill it too should be spinning.?
Not on a 97. If the electric fan is spinning you are about to experience a thermo nuclear meltdown. Mike is correct referencing the center of the A/C compressor.
Old July 26th, 2005, 10:50 PM
scubadanster
daniel park
1997 defender 90
okie-dokie...
took a look......it blows air, but NOT cold...
popped the hood....had no idea what i was looking for! lol! arrrghh..
the front fan on my 97 did NOT spin......will my rig still blow up??
gracias..
-dan
Old July 29th, 2005, 01:37 AM
scubadanster
daniel park
1997 defender 90
so!! no answers for me, fellas??????
-dan =(
-dan =(
ps> how much would a new unit cost me??
Old July 29th, 2005, 02:12 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Did it suddenly stop blowing cold air? or did it slowly go bad? Might need a recharge (R-12? R-134? Don't have A/C, dont know what it takes)
-Hans
My oil line fix
My 100k stopped odometer fix
Old July 29th, 2005, 10:51 AM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
Originally Posted by scubadanster
okie-dokie...
gracias..
-dan
Dan, Here's some pics of where your compressor is in your engine. Look for insulated pipes going to and from it. The front (viewed from standing in front of your truck) of the compressor has a pulley that turns all the time with the serpentine belt also turning your alternator, steering pump, etc. In the center part of this pulley does NOT turn if the A/C is off. It should turn while the A/C is on. Turn your A/C temp control to cold and turn the A/C fan on. Go in front and look at the center of teh A/C compressor pulley; it should be turning. If it is not turning, you can check the fuse on the bulkhead (firewall). At least on the '94's is on there. Not sure about the '97's.
ID:	3484   Click image for larger version
Old July 29th, 2005, 02:50 PM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
Also, I'd love to know why an air conditioning condenser fan doesn't have to be turning. There is no other application* of this type of heat exchanger where this fan is not supposed to be on, including all the other Land Rover models of 1997.
*Except this one:
Old July 29th, 2005, 05:29 PM
scubadanster
daniel park
1997 defender 90
hmmm...will take a look.
thanks..
anyone know how much this is gonna cost? that is, if i need a new one??
-dan
Old July 29th, 2005, 06:22 PM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
thanks..
-dan
Unplugged compressor = $0
All new a/c installed $2500+
or any thing in between.
Old July 29th, 2005, 08:01 PM
tron's Avatar
tron
Thomas F
Recently Roverless
Dan--
If you feel like driving to LA next week I will be in Brentwood for a few days (Thursday - Sunday) and I would be happy to take a look at it with you before you take it to the shop.
Tom
Old July 31st, 2005, 05:46 PM
scubadanster
daniel park
1997 defender 90
Aw~
thanks, fellas...and thank you Tom for such a kind gesture........but i got it figured out...
really poor design flaw:
on the 97, the compressor "pipe"..the one that gets cold and wet with condensation.....well...the sucked had a hot tube sitting against it....simply melted the pipe! wow....
so the local radiator shop simply welded it back......kinda cheesy....but it worked....and filled my freon up......all for $100.....good deal??
happy and cooler,
-dan
Old August 2nd, 2005, 03:15 PM
Mendicant
glad you got a cheap and easy fix to your problem.
to answer the question on the fan, the 97 system (and I think 95 too) is fitted with a tri-function pressure switch. At 2 atm, the switch turns off the compressor because pressue is too low. At 30 atm, the swtich turns off the compressor because pressure is too high. Most of the time, the switch turns on the fan at 17 atm and turns it back off at 12 atm to regulate pressure inside that range.
Old August 2nd, 2005, 05:32 PM
scubadanster
daniel park
1997 defender 90
wow!
jim! you da man....thanks for that 411...
but i just think it was a bad way to position the ac line in contact with a small rubber hose....
nonetheless, works great now...
thanks!
-dan
ac
Making AC Lines Lesandjes Defender Technical Discussions 3 July 10th, 2008 12:58 AM
HELP, HELP Dead D90 in CT januconn92 Defender Technical Discussions 16 July 8th, 2005 08:20 PM
Need a DEAD EFI computer for parts Hans Wanted 0 December 5th, 2004 03:21 PM
Dead Battery...maybe? Antonios Defender Technical Discussions 11 November 17th, 2004 10:41 AM
Water pump pulleys - got a dead 3.9 laying around? jaherring Wanted 3 September 9th, 2004 09:16 AM
