DAP bushings - Defender Source
Old April 15th, 2005, 09:22 PM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
DAP bushings
Is anyone using the DAP bottom link to chassis bushing set,and, or the OME caster correcting bushings ? The DAP bushing set claims to stop tail end steering.Are the OME caster correcting bushings worth getting? Vehicle has 4" lift,Trying to change my worn out suspension before Rausch creek trip.Thanks for any input.
Old April 18th, 2005, 04:11 PM
jorge's Avatar
jorge
JORGE ESPINOZA
Anyone with any input?
Old April 18th, 2005, 07:39 PM
Jorge I tried searching it and din't turn much up here or on Pirate, I thought I remembered someone talking about the DAP stuff but I think that may have been the Adjustable rear ball. Are you having steering problems or anything bad that you don't think new parts won't fix?
Old April 18th, 2005, 08:03 PM
jorge's Avatar
jorge
JORGE ESPINOZA
My frontend is a bit lose, when I hit a bump it tends to shake & vibrate . I'm trying to rebuild the frontend with new balljoints,bushings(stock except for the Dap stuff),springs,GRB fr driveshaft, and probably new front radius arms from RTE. I'm press for time ,but all the parts came today.Now I need someone to do the install before this weekend,want to make the Rauch creek run.I NEED TO HEAR THE D-90 SUSPENSION CREAK ,GROAN,AND SCRAPE ON THE ROCKS AND GET MUDDY & WET.Hope you can understand ,it's time to play.
Old April 18th, 2005, 08:05 PM
LOL! Yeah I know what your missing! I haven't driven mine in some time, although I got to play in the snow over the winter a little.
Old April 18th, 2005, 08:39 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
you can check with Vinnie at Rover Specialists in NJ, his prices are a bit high, but he probably could get everything in for you by the weekend. I think he charges $90hr. (201) 943-8213
bushings
Slotted Radius Arm Bushings -- Opinions? LRNAD90 Defender Technical Discussions 7 June 19th, 2006 11:37 AM
Body bushings - poly or factor rubber?? jaherring Defender Technical Discussions 15 February 10th, 2005 06:42 PM
Rockware Trailing Arms w/ good bushings lwg For Sale - Parts 1 January 9th, 2005 04:06 PM
Greasing bushings ronward Defender Technical Discussions 1 July 25th, 2004 11:30 PM
DAP Enterprises Nobrega Defender Technical Discussions 9 May 11th, 2004 02:59 PM
