DANGER - wheel spacers maintenance - Defender Source
Old July 4th, 2010, 10:57 PM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
I took my vehicle for service for a noise coming from the rear axle area that started 2 days ago . I had checked the area of the noise but found nothing lose . My mechanic called and stated that the front driver side wheel spacer was so lose that when the vehicle was raise on the lift the wheel could be moved by hand in and out .The mechanic checked all spacers and found all to be lose and some spacer nuts could be turned by hand . All the surfaces were cleaned and the spacers reinstalled with loctite . Please check your spacers , this incident could have turn very ugly specially at HWY speeds . Happy fourth to all.
Old July 4th, 2010, 11:06 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
you got those cheap ones from eBay or the expensive ones?
1955 Series I
1975 FC101 Vampire
1994 Defender 90 #916
1967 Lancia Fulvia
1974 Alfa Romeo GTV
Old July 4th, 2010, 11:40 PM
jorge's Avatar
jorge
JORGE ESPINOZA
Have these on the vehicle but I think my problem was trusting a local tire shop install . My mechanic stated the problem was probably due to the dirty surface of the wheel hubs when initial installation of the spacers at the tire shop. http://www.ezaccessory.com/Wheel_Ada.../5650-5650.htm .
Old July 5th, 2010, 09:39 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I've been using a set from RTE for about 8 years and never have had an issue with them coming loose. The only thing I don't like about them is the studs are a different thread, so I use steel Rover lug nuts to hold them on the hub, but have to use the lug nuts that came with them on the spacer studs. But they work fine.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 5th, 2010, 01:01 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Doesn't hurt to check the tightness of the lug nuts every once in a while either. After I had my new tires installed at a shop I did a lot of driving on dirt roads (a lot of vibration). One day driving back from Mt Hood I got crazy vibrations in the steering wheel going 70mph on the freeway. Turns out all but one lug nuts had vibrated loose and fallen out. I only had one semi loose lug nut left on one of the front wheels! Could have been ugly. Now I use Loc Tite (or similar) and check the tightness periodically.
Old July 5th, 2010, 03:27 PM
Antichrist's Avatar
Antichrist
Tom Rowe
I always use Never-Seeze on lug nuts, have for the last 30+ years. I've never had any come loose, but I always use the right lug nuts for the application and torque to spec.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old July 5th, 2010, 07:15 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
They were Toronado lug nuts for Toronado wheels and they were torqued to spec at the tire place where I bought them. Excessive vibration seem to have loosened them. Big fan of the anti-seize since then.
Old July 5th, 2010, 08:33 PM
Antichrist's Avatar
Antichrist
Tom Rowe
Weird. The only wheels I've seen where lugnuts would come loose during use was the old white spokes in the 70's, where the centers were just steel plate and didn't have the crush zone around the studs.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
ac, wheel, wheel spacer
Need wheel spacers. tobit3 Wanted 9 August 4th, 2005 03:01 PM
Safarigard 1" aluminum wheel spacers dannykkim Defender Technical Discussions 1 March 7th, 2005 04:29 PM
wheel spacers krisp For Sale - Parts 15 November 30th, 2004 11:03 AM
Wheel spacers Dfndr90 Defender Technical Discussions 1 September 9th, 2004 12:22 AM
Wheel Spacers? Joe P Misc. Chit-Chat 5 April 9th, 2004 12:24 PM
