Dana 60 parts in a Salisbury axle? - Defender Source
Old April 30th, 2011, 04:24 PM
nopants
Joe
1985 Defender 110
I would love to run an Eaton E-locker in the rear of my Defender, but it is not available for the Sals axle. It is, however, available for the D60. I am under the impression that these parts will fit, with or without some possible modification.
Pinion bearings are different, and require part #s HM88644 and HM88610.
Ring gear bolt size is different, which is remedied by using D60 gears.
Now my questions start, mostly to do with axles and spline counts.
The Eaton E-locker is available in either 30 or 35 spline. The Sals has 24 spline axles. What is the solution for this? It seems like Dana 60 axle shafts are needed, but then what do you do about wheel bearings, seals, bolt pattern, hubs, etc.?
The splines on the pinion will be different which would require a Dana 60 Driveshaft flange? Will this bolt up to the Rover driveshaft? Any part number for one that works?
Old April 30th, 2011, 04:39 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Give Kieth at rover tracks a call. He's the man, for all your axle needs.
Old April 30th, 2011, 04:58 PM
You would need 30 spline shafts. x2 on calling keith. My understanding is you can reuse your ring gear if you are sticking with 3.54.
Old April 30th, 2011, 05:05 PM
nopants
Joe
1985 Defender 110
I emailed Rovertracks a week or so and got no reply.
I will be sticking with 3.54.
If axle shafts are needed, then I guess I would need to machine the stub axles to accept them and do something about the hubs? This might be getting a little too expensive.
Old April 30th, 2011, 05:46 PM
Keith does all that. I would call him. Personally, the detroit is cheap for the sals so I would run that.
Old April 30th, 2011, 06:22 PM
nopants
Joe
1985 Defender 110
I've run Lock-rights, detroits, e-lockers, arbs, etc., in the past. The ability to turn off the locker is something that I do not want to give up, especially knowing that the vehicle will be for sale at some point.
I guess Ill give him a call on Monday. Seems like he would respond to emails if he wanted to make some sales though.
Old April 30th, 2011, 10:13 PM
He may be traveling.
Old May 1st, 2011, 02:47 PM
Cube II's Avatar
Cube II
Michele
1997 D90
He may be as busy as usual if not more...
Michele
D90 VNTdi
+109" IIA ex-military
Sketches and doodles:
[O]===[O]
Old May 1st, 2011, 04:45 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
Another vote for calling Keith - your email might have gotten sidetracked or he has been traveling/busy. Emails are usually easier but something like this would probably be better discussed over the phone. He answered a ton of my questions about his Toy conversion kit and was great getting things together for me.
Good luck with the Elocker setup - it sounds interesting.
Old May 3rd, 2011, 09:18 AM
revor's Avatar
revor
Keith Kreutzer
Old beat up 110
Sorry Nopants, I don't think I ever got your E Mail. I check them always. Sometimes my server gets a little overzealous. Try rovertracks@hotmail.com.
An Eaton can Certainly be done.
Keith
Big, Red and ... aaa Red..
Old May 4th, 2011, 07:18 PM
nopants
Joe
1985 Defender 110
I just wanted to update this and say that I did talk to Keith at Rovertracks and he was very helpful. Spent a fair amount of time on the phone answering my questions and explaining things.
I still have not decided what exactly I am going to do, since the D60 "conversion" is going to cost more than I was hoping.
axle, part, parts
Salisbury Axle with a welded on stub axle, disc brakes, Factory? Capt Milks Defender Technical Discussions 5 December 21st, 2010 09:45 AM
Complete HD Salisbury Rear Axle For Sale Northface For Sale - Parts 4 July 21st, 2006 08:29 PM
Salisbury Rear Axle for Sale Northface For Sale - Parts 1 August 12th, 2005 06:54 PM
Disc braked rear Salisbury axle Shane@EVS For Sale - Parts 2 August 6th, 2004 05:59 PM
New Rover 9in almost ready Buckon37s Misc. Chit-Chat 55 November 12th, 2003 02:53 PM
