Damn, my driveline is noisy! - Defender Source
Old November 29th, 2009, 11:07 AM
The 90 has developed a new noise and I thought I'd see what sort of guesses were out there as to the cause.
At higher RPM's (as when cruising on the road) the truck sounds like a floor board has been removed - its just damn noisy, and this is a recent development.
There is no vibration, it doesn't sound like the high-pitched whine of a neglected transfer case. Its more of just a loud driveline noise.
I've checked all the fluids, t-case is full, trans is full, drive shafts seem to have no play, etc. I'll double check everything as soon as possible, but in the meantime it seems like all is in order.
I can tell I have some sort of engine oil leak, perhaps from the rear of the oil pan.
This is really confusing me, it seems to have come from nowhere...
Old November 29th, 2009, 11:36 AM
Exhaust hitting anything?
Old November 29th, 2009, 12:44 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Are the nuts that hold the flanges securely tightened on the pinion and t case sides? I had this on my series rig, tight bolts connecting the driveshaft to the flanges but the bolt holding the flange to the transfercase was finger loose. When examined it all felt solid until I pulled the driveshaft.
Old November 29th, 2009, 01:14 PM
I actually found a couple of the bolts that hold one of the trailing arm bushings had worked loose and I totally thought I had found the smoking gun at that point. Unfortunately, I hit the road and the noise was still there. I'll check these things you guys mentioned.
Old November 29th, 2009, 02:07 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
Jim-
Make sure you chock the wheels, take it out of gear and leave the parking brake off when checking for play in the UJ's
Does the sound go away at freeway speed when you are in neutral or have the clutch in?
Damn! Cannot figure out what is wrong with the lights! solihul Defender Technical Discussions 11 October 26th, 2017 07:04 PM
driveline locks up stevewhitaker Defender Technical Discussions 14 February 26th, 2005 03:14 PM
Driveline (shaft) problems continue... P1CR Defender Technical Discussions 2 July 16th, 2004 10:39 AM
damn heater removal! alternative replacement? artm Defender Technical Discussions 7 October 15th, 2003 09:20 AM
