Damaged A/C line for probe that goes to evaporator - Defender Source
Old July 1st, 2012, 09:00 AM
mattb's Avatar
mattb
Matt
94 D-90 No. 44
Hi Everyone,
I have a 94 NAS D90 and there is an A/C line that runs from the A/C switch on my dash, behind the plastic fascia, and down to the evaporator unit. This line is damaged/broken open. Apparently from my research this line is a probe that checks temperature and controls the cycling of the compressor.
Is there any way to fix this line? It appears to be a soft metal, like copper but it is very thin. I have plenty of it to work with but I am not sure if it is something that can just be spliced back together.
Any help is appreciated.
Old July 1st, 2012, 09:05 AM
Originally Posted by mattb
Hi Everyone,
I have a ’94 NAS D90 and there is an A/C line that runs from the A/C switch on my dash, behind the plastic fascia, and down to the evaporator unit. This line is damaged/broken open. Apparently from my research this line is a probe that checks temperature and controls the cycling of the compressor.
Buy a new one ... http://www.nostalgicairparts.com/ac/...rmostat-93.php
Old July 1st, 2012, 09:12 AM
mattb's Avatar
mattb
Matt
94 D-90 No. 44
awesome! Thanks Jason. While I am at it, do you know how the probe is attached to the evaporator? I haven't looked at it closely yet but it just seems to run into the fins without any obvious connection point.
Old July 1st, 2012, 11:04 AM
mattb's Avatar
mattb
Matt
94 D-90 No. 44
I just took a closer look at the evaporator and the "capillary probe" just inserts into the evaporator. So hooking up the new switch should be pretty easy, with the exception of removing the dash!
damage
a/c evaporator and vents One Ten Wanted 2 August 22nd, 2011 10:55 PM
A/C line and overhaul 97Ariesblu Defender Technical Discussions 0 April 29th, 2007 03:50 PM
A/C line for 97 97Ariesblu Wanted 0 April 29th, 2007 03:40 PM
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
97 low pressure A/C hose source dnewman9 Defender Technical Discussions 1 June 15th, 2004 01:39 AM
