d90 won't start after pressure washing - Defender Source
Old January 18th, 2007, 06:58 PM
Bruce Brown
Bruce Brown
1997 D90 SW
I should have known better, but I wanted to make sure all the road salt was gone and pressure washed my '97 D90 SW. Now it won't start... It has a valet remote start system that might be part of the problem. Engine will crank, but won't start. Have tried using blow dryer on elecrrical components... any suggestions besides "don't do that again!"? Thanks!
Old January 18th, 2007, 07:49 PM
dnp
David
1995 Defender 90
If it's the same with mine, most likely you've gotten moisture into the coil connection(s) Take the coil wire off the coil and spray it (and the other surrounding connections) with WD-40 On mine, that displaced the water and got everything running again......Hope this works for yours
Old January 18th, 2007, 09:59 PM
artm
Arthur Maravelis
97 SW
Road salt in FL? Still haven't seen any this season up here!
Did you really pressure wash it? Why not just hose spray it???
Old January 18th, 2007, 10:20 PM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
I always heard if you're gonna wash the engine leave it running, does this make any sense to anyone looking at this (sorry for the highjack). Also, you get any water in the dist. cap?
"It's not a Jeep"
Old January 18th, 2007, 10:27 PM
Tim Scully's Avatar
Tim Scully
Tim Scully
95 D90 SW/ 95 RR LWB
Yeah, I normally leave it running if I am washing the engine. He couldnt have water in the dist cap, he doesnt have one.
You might have water in on of the conectors by the coils at the rear of the engine, maybe you got some water in the ECU under the box on the right side of the engine. Past exp was taught me that it usually drys out in short time so it should start soon hopefully :D
Old January 19th, 2007, 12:22 AM
JBurt's Avatar
JBurt
Jesse McCoy
Yeah, I'm an idiot.
"It's not a Jeep"
Old January 19th, 2007, 10:07 AM
artm
Arthur Maravelis
97 SW
Why would you have the motor running? Water's a pretty good conductor and it does wonders getting into the intake.
Old January 19th, 2007, 11:11 AM
JBurt's Avatar
JBurt
Jesse McCoy
Please see post above...
Truly it's one of those, heard it from a buddy, who heard it from a buddy things.
"It's not a Jeep"
Old January 19th, 2007, 11:14 AM
dnp
David
1995 Defender 90
..........He couldnt have water in the dist cap, he doesnt have one.
OOOPS! You're right. Didn't notice it was a '97. Sorry for my incorrect post above.......
Old January 19th, 2007, 01:38 PM
Your computer is wet. Turn everything off, and shake the water out of the bottom of it through the drain hole. Leave it plugged in if you can. The sure way to tell is if you have a check engine light when you first turn on the truck that goes off after a few seconds. If not, you got the computer wet.
Next most likely is the crank sensor.
Old January 19th, 2007, 05:49 PM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
Any luck, Bruce, on getting your D90 started? I'm curious what worked.
Old January 19th, 2007, 09:47 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Pressure wash force water where it is not suppose to go,
search for those places and dry.
Good luck.
- Charles Eames
Old January 20th, 2007, 01:35 AM
MattGuyver_007's Avatar
MattGuyver_007
Matt VA
1995 D90 SW
...and of course, check all fuses.
Old January 23rd, 2007, 09:48 AM
Bruce Brown
Bruce Brown
1997 D90 SW
Back to normal. Used hair dryer. Thanks for all the advice!
90, d90, start
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
Non D90 Technical Question jump start polarity problem dnewman9 Defender Technical Discussions 4 September 6th, 2004 05:39 AM
