D90 won't start! - Page 2 - Defender Source
Old January 6th, 2004, 10:07 PM
Art Vigil's Avatar
Art Vigil
Arthur Vigil
5w30 seems a little "lite"
Been running Castrol full synthetic 5W30 for several years in two different D90's with no problems (so far).
Arthur M Vigil
Colorado Native
Former owner of:
'95 RRC - 3.9V8 Rimmer Supercharged!
'72 Series III 88" NADA Turner 2.25 petrol (Lovely Rita)
'95 RRC Brooklands/TWR Edition 3.9V8
'97 D90SW NAS #2426 - 3.9V8 Rimmer Supercharged!
'95 D90ST NAS#2620 - Original owner
Old January 7th, 2004, 10:01 AM
Eric_S
Eric
'97 D-90 ST #1507
FWIW,
Here is the response from Mike Hippert for the sump oil chart from the owners manual that I posted a few weeks ago....
"And the Book says, 6.5 quarts for the oil sump
5W/30 -22 to 90
5W/40 -22 to 122
10W/30 -4 to 90
10W/40 -4 to 122
15w/40 14 to 122
20W/40 32 to 122
25W/40 60 to 122"
Right now in Boston, MA it's a balmy 18 degrees with nighttime temps for the rest of the week in the single digits. So I use 5w/30 in the winter and 10w/40 or 20W/40 in the summer.
Eric
Old January 14th, 2004, 05:56 PM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
I got my truck back from the shop yesterday and the difference is dramatic. Not only does it fire immediately and start right up on cold starts, but the stumble on acceleration around 2200 rpm is gone. I highly recommend the $13 ecm prom for anyone with these issues. (Also put in a new ignition coil).
Old January 14th, 2004, 07:43 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Good news & thanks again for the info Phil. My ecr prom is on the way!
DJ
Old May 27th, 2004, 04:16 PM
BrknRvr
Ben Kemple
Locked '94 D-90 33"MTR
Question Rover Won't Start
I have a 94 D-90 and it won't start. It turns over and is getting fuel and spark. I am not sure what is happening. If you have any ideas please let me know what to do. I will try anything.
BrknRvr
Old May 27th, 2004, 10:00 PM
Is your ECM getting power? What did you last do before it stopped working?
Old May 31st, 2004, 05:05 PM
LamontD
Marc Domsky
97 D-90 soft top
Won't start!!!
I'm pretty new to this. Have a 97 d-90 that was running well. Did not use it for couple of months and when I went to start it, cranked but would not turn over. Played with the plug wires (rotated around) and still wouldn't start. Next day started without a problem. Today, same thing, crank but no start. Disconnected #1 wire and spark present. Disconnected fuel line after filter and minimal flow on cranking engine. I then disconnected fuel line before fuel filter and still minimal flow on cranking. Is this a fuel pump problem and/or relay problem? Any help would be appreciated.
Old May 31st, 2004, 05:28 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Hi Marc, welcome to the forum.
There are a couple other threads that may present some help on this subject. I will merge them and hopefully they will help you out.
Chris von C
[/size]
Old June 1st, 2004, 03:00 AM
My guess would be on a 97 to check the inertia switch, and if it is ok look at the fuel pump. You should hear it run when you turn the ignition.
I have one ECU with the cold start prom and one without and I can't tell the difference. BTW the dealer I worked for put 5w 30 in all the D90s (there were quite a good number in the area) and never had any oil light/pump issues.
I am willing to bet the coil was the main issue. there is an interesting bulliten on excessive dwell angles and how it kills the coil. there is a whole update involved--ignition module etc. Saw it happen twice. one it actually melted the coil so it started to leak black stuff. nasty.
some things to keep in minds when diagnosing these type of issues.
Old June 2nd, 2004, 11:48 PM
LamontD
Marc Domsky
97 D-90 soft top
Thanks for the help. In the works right now!!
Old June 14th, 2004, 05:36 PM
LamontD
Marc Domsky
97 D-90 soft top
Fuel pump replaced and it works like a dream. Thanks for the help!
Old June 11th, 2005, 06:48 PM
PJ Naples
P.J. Lodge
97 Defender #140/300 w gr
man, will take this info to garage
Originally Posted by Kent Welsh
I bought this truck about three months ago. For about the last six weeks I've had trouble getting it started. I'm not much of a mechanic so it's been dealt with at the local dealership.
It turns over and will crank and crank but not fire. Sometimes you can try it again and it will start but still reluctantly. So far we've replaced the ignition module, fuel pump and all of the wiring to the fuel pump and it's still doing it. I've just ordered a water temperature sensor but it's been suggested that since my plugs aren't soaked when I pull them out after cranking that that's not going to be it. Any help?
Hi Kent, PJ (Polly) Lodge here in Naples....I had that same problem with my 97 D90, thought it was just "bad gas"- after two or so tanks it stopped...I was THRILLED! then today in the Publix parking lot- it would start, but not STAY on.
I'm looking for a solution and would appreciate your advice! Polly
Old June 13th, 2005, 08:42 AM
Hey Polly, any engine codes? I know a little about the 97's system.
90, d90, start
HELP 94 d90 will not start ripp2002 Defender Technical Discussions 64 August 25th, 2005 08:43 AM
D90 won't start dameek Defender Technical Discussions 1 November 11th, 2004 09:00 PM
Non D90 Technical Question jump start polarity problem dnewman9 Defender Technical Discussions 4 September 6th, 2004 05:39 AM
95 D90 Can't start !!!!! Vadim Defender Technical Discussions 14 July 28th, 2004 03:52 AM
