D90 withdrawl :( 110 build :) - Defender Source
Old October 21st, 2004, 09:57 PM
D90 is gone
But I am going to get rolling on the 110 build since I now have JimC's old drivetrain.
Questions:
1. Can someone please measure the length of a 110 rear drive shaft, V8 and/or 300 TDi.
2. What options are available for side tanks on a 110 SW
3. What do the connections look like on the ignition switch and does anyone know of a reasonable substitute.
4. I do not have a tach, is the tach in the ciruit with the alternator or will the alternator charge without it?
5. I do not have a fuel gauge, this does not particularly bother me but does anyone have the specs as I would be inclinded to use the series one if it was compatible.
6. I need the support stuff to mount the radiator, does anyone have it used?
7. I also need the stuff for the steering colum. Anyone have this used? Would RHD fit? Would a RRC stuff fit (this was my plan)
8. Does anyone have measurements for locating V8 engine mounts on a 110?
9. I am planning on using TDi X member mounts for the t-case, is this ok?
Ron
Old October 22nd, 2004, 12:54 AM
pendy's Avatar
pendy
jim pendleton
89'd90
I have a 93'D110 fuel tank complete if you need it. The Tdi weld on mount jig I have, also has the location for the V8 chassis mounts. And I still have a couple chassis mounts for V8 as well. The alternator has a W terminal that will send a tach signal.
May have a D110 driveshaft as well.
JP
legend in my own mind
Old October 22nd, 2004, 08:09 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ron, I have a steering colum I also have a main wiring harness
Legend in My Own Mind.
Old October 22nd, 2004, 08:11 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Ron,
Mantec sells a tank: http://www.mantec.co.uk/index.cfm?pa...ail.cfm&id=945
Depending on what they want for it, I would recommend finding a boat builder who specializes in custom tanks. That's a better route usually.
Old October 22nd, 2004, 04:39 PM
Pendy, is it a side tank? I have a rear one. I have to buy those V8 mounts off you, send me an email. evilfij at yahooooooooooooooooooooooooooooo . com delete extra ooooos
What do you want for the 110 rear driveshaft? I am pretty sure it is the same length as a 93-94 LWB driveshaft (95 have rotobomb) which I can find inexpensively (wife bought 04 rangie so I am temporarily poor).
Randy, I have the main harness thank you. The steering colum you have is only the shaft little piece, I need the whole shebang brackets, wheel, everything from the box up, do you have the rest as well?
Ron
The side tanks I want are the ones under the seats.
Old October 22nd, 2004, 06:05 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
Ron, I have the full steering colum and the bracket/cap that goes on the bulkhead. You still would need a few of the other small brackets though.
Old October 23rd, 2004, 01:04 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Ron
Sorry Ron it is a rear tank. I have a D90 side tank that I cut at the seam and welded a bottom there. It leaks but the price is right. shipping.
The driveshaft is left from a cust. truck. I will ask a price for you. What is fair?
V8 mounts 20-30$ plus shipping and LR novelty. pendy1@cox.net an address. But I will check on the shaft for you first.
JP
110, 90, d90
Build a 110? Chaucer Misc. Chit-Chat 36 March 19th, 2008 08:27 PM
Looking for a wrecked D90 or D90 frame & body mdb77 Defender Technical Discussions 17 January 11th, 2005 09:54 PM
97 D90 SW - Inner rear door panel Kimos Wanted 5 December 2nd, 2004 09:26 AM
