D90 will not start possible ecu or wiring? - Page 3 - Defender Source
Old December 24th, 2014, 11:30 AM
richpmnelson
Rich
95' Land rover d90
Does the relay not power up for a second or so with the ignition? If that's not happening it's likely a fuse.
If you hear the sound of hooves think horses not zebras.
the fuse is good if i ground pin 16 at the ecu connection and turn on the ignition the pump kicks on. have a look at page 11 test 6 in the folowing link.
http://www.g33.co.uk/images/PDFS/14c..._injection.pdf
Old December 24th, 2014, 12:07 PM
Originally Posted by richpmnelson View Post
hmm.. ill have to check that ive already got the dash apart, but it shouldnt effect anything it the end of the line comming from the ecu.
CEL being blown won't cause an issue.
Is fuse 18 in the main panel good?
Old December 24th, 2014, 12:10 PM
richpmnelson
Rich
95' Land rover d90
yes please read my last post.
Old December 24th, 2014, 01:05 PM
Back to pin 39. When you crank does it pulse? That is the signal for the ecu to turn the fuel pump on once the pulses are occurring at a fast enough rate and also fire the injectors.
Have you checked that the fuel rail is pressurizing ? Just thinking if it died during normal operation the fuel filter could have blocked.
Old December 24th, 2014, 01:48 PM
richpmnelson
Rich
95' Land rover d90
the pump is not even priming, when i hot wire it i get pressure at the rails. when it died i noticed that the pump had turned off while driving. for some reason the ecu just stopped sending power to the pump relay.
Old December 24th, 2014, 03:23 PM
Do you have a rovergauge? I can send you a cable if you PM me your address. You'll need to assemble it as I don't have all the heat shrink at my apartment.
It's only solder 3 connections.
This should give you a bit more insight to what the ECU is doing with regard to the pump.
The pulsing on pin 39 is required to start the pump up for the second time after the initial prime which only lasts a second or so.
Old December 24th, 2014, 08:47 PM
richpmnelson
Rich
95' Land rover d90
i will probably be busy for the next couple of days, thanks for all the help you guys have given. have a merry christmas or happy holidays, witch ever you prefer.
90, d90, ecu, start, wiring
2 4.2 ECU's 1 3.9 ECU eliaschristeas For Sale - Parts 3 June 19th, 2013 03:15 PM
Start no start leastonce Defender Technical Discussions 10 February 25th, 2012 02:33 PM
no start... ECU? MikeRuby Defender Technical Discussions 18 August 3rd, 2010 06:36 PM
Need an ECU... looking for the ECU out of a 95 Disco or equivalent IPSC_GUY Wanted 7 February 16th, 2010 04:36 PM
